Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
When put my data traveller mini 1 gb to my computer , Display message "Please insert a disk into disk E"
  • Kingston Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Apr 08, 2011
Not working USB data travelter 4 GB message error is USB device not recognized plz solved this problem and send me best clarification.
Hello and Welcome to FixYa!
The error you quoted can be due to multiple reasons. Following are some main Possibilities, that you should keep in mind.
Make sure, the USB port, you are inserting data traveler in, is in working condition. And you are connecting the device properly.
This could happen due to Software conflict, for this you need to remove all the devices connected to USB ports (other than keyboard, and Mouse) and need to restart the system.. Moreover, you can check for the exact error, in the device manager list...
Try checking the data traveler, on some USB port, on which you are sure, that its working properly.
Check for the possibilities, quoted above and do let me know....
Concerned.
Jun 25, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When I try to mount my 500gb minimax on my mac mini, i get this message: "Disk Insertion, The disk you inserted was not readable by this computer." When i click on "initialize" and then...
Unfortunately, that does not sound good. What format is your drive? (Mac OS extended/ FAT32/ NTFS/ etc). If it is a mac format you could try something like drive genius to hopefully be able to get it working again. If it is a different format you could try G-parted or there are a lot of good tools on ultimate boot cd (although they are kind of geeky and hard to use).
http://www.ultimatebootcd.com/
Unfortunately if it is starting to die, and the info on it is really valuable to you, your only option may be able to send it off to a data recovery place, but they are VERY expensive (sometimes $1000+ and it's not even guaranteed to work). I wish I had better news.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 04, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
The 1 gb pen drive is shown in my computer & and the task bar but on clicking the icon the "Insert Drive " message is displayed.
Try to run a disk check.
Right click on the drive's icon, select properties, go to the "tools" tab.
Select "check for errors".
Depending on the operating system on your computer, this could be called "run scan disk", "run disk check" or "check volume for errors".
Jan 24, 2011 | Electronics - Others
HOE TO FORMAT DATE TRAVELER
The simplest way to format a Flash Drive or a Pendrive is to format it from the My Computer without using any commands. Let's assume you are doing it on a Computer (Pc Desktop). Follow the instructions;
1. Connect you Data Traveler on one of the Usb port of your computer, and wait for few minutes.
2. After you know that it's been detected by the computer, open "My Computer" then right-click on the Data Traveler's Drive Icon e.g. Removable Disk (K:), etc.. and select "Format"
3. When the format dialog box is opened, click "Start" and then you'll be prompted with a warning message to confirm the proceed, click "Ok" to proceed. Formatting Dialog box bf3d566.jpg
Format Warning Message
4. Wait for few seconds and you'll get another message that the drive has been successfully formatted.
If you have problem, please let me know. Good luck.
Thanks for using FixYa.
Jul 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My USB giving message of Insert a Disk into drive !
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
Apr 16, 2010 | Electronics - Others
Disk is write protected
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Jun 27, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Jun 22, 2009 | Kingston Technologies 512MB DataTraveler I...
I had problem with imation lock
how format flash imation 8 gb write protected
Mar 25, 2009 | Electronics - Others
Pen drive
First thing is you can try to detect your pen drives with Linux.
(DSL Linux is just about 50 MB download. You'll need to burn it on to a CD as an IMAGE and not copy on the CD directly, then boot with the CD.It will automatically mount your USB drive and you can cpy the data to your hard disk and later format the USB drive.)
Get it from here: http://damnsmalllinux.org/download.html
If that too fails, then you can try recovering using a data recovery software. Or contact me and I can personally help but a live chat session would be better since posting here will take and waste time. You could contact me on
rsletters-fixya@yahoo.com
and then we can proceed to chat and solve this issue. I won't take any charge. I'll be happy helping getting the data since I know how it feels to lose precious data.
HTH,
Regards,
Deboo
Feb 16, 2009 | Compaq Computers & Internet
My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Oct 29, 2008 | Transcend (589307) Media
Computers & Internet Logo
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
