Question about Sony Handycam DCR-PC330E Mini DV Digital Camcorder
DCR PC330E. The CHG keeps flashing (orange) but still unable to power up the camcorder. Same problem occurs when it is connected to the charger via outlet cable.
techman
  • 3130 Answers
SOURCE: SONY HANDYCAM DCR-PC330E
This is not a monster you wanna open and play with as I've seen this puppy and its loaded with flex cables connecting all the differant pcb's together. You wanna take this or send out to a camcorder specialist please. You also need a special set of these cables to work on this unit as well as a few special service jigs. Good Luck
Posted on Apr 12, 2006
magic seadog
  • 38 Answers
SOURCE: sony dcr-trv6 unable to load tape in deck
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Posted on Aug 12, 2007
welcomejee
  • 10594 Answers
SOURCE: DCR-SR42 Camcorder does not power up
I think AC power charger of your camera got defective first and later on battery lost its charge so no power for camera now to power up.
Try to borrow same charged battery from friend. neighbors etc and test your camera.
If camera power up, it is sure that charger has gone and you need new one.
let me know in that case to guide you further.
Posted on Oct 05, 2008
snp_06
  • 22 Answers
SOURCE: cant connect my sony camcorder to comp via usb
do you still have the software that came with your camcorder? if not you just need to finalize the disc and connect via usb and use a dvd ripping software. if yes then you still need to finalize disc and use the software to transfer videos to pc.
Posted on Apr 01, 2009
  • 273 Answers
SOURCE: DCR-PC330E to MacBook Pro
unfortunatley all sony products only work on pc your best bet would be to transfere to dvd and import that way
Posted on May 27, 2009
Dcr dvd106e handycam sony
non replacable builty in rechargable
Nov 22, 2013 | Sony Handycam DCR-DVD108 DVD Camcorder
I pluged my DCR-SR47 vCam on my pc then it wont turn on i thought that it just have an empty battery but after i charge it i still cant turn it on only the red flash below the battery is blinking
  • try the following.
  • remove the battery and connect the AC adapter
  • Turn on the camcorder (without battery)
  • If the camera turn on, maybe you need replace the battery (lifetime one year)
  • Place the battery sliding it in the direction of the arrow
  • Connect the AC adapter in Jack (camcorder)
  • The Led Charger "CHG" lamp lights up. When the battery is charged, the light turn off.
  • I hope the information will be helpful.
    Is importan to people who share knowledge hear your comments or received rate points.
    Sep 17, 2011 | Cameras
    How can I charge my dcr-sr47 camcorder with a usb cable and my pc?
    You may not be able to.
    Most cameras require a stand alone charger for battery charging.
    Some models will allow in camera charging via a connecting dock or purpose builtl power cable.
    Your camera manual should advise .
    Feb 04, 2011 | Sony DCR-SR47 Camcorder
    Cant instal drivers
    usb streaming function is not readily supported by windows vista. this would depend on the software that came supplied with the camcorder. unfortunately, the software being incompatible and the funtion (usb streaming) not supported by driver included in the supplied cd-rom, usb connection will not work (although you can use it for still picture transfer). for tape transfer you would need to go another route which is ieee1394 (ilink or firewire) connection. it should be a plug-and-play connection. your computer should support and have a working ieee1394 (ilink or firewire) card installed. a compatible ilink cable for both devices and a video capturing software like windows moviemaker and having all the needed hardware and software then your good to go. hope this helps.thanks:)
    May 29, 2010 | Sony Handycam DCR-PC330E Mini DV Digital...
    May 27, 2009 | Sony Handycam DCR-PC330E Mini DV Digital...
    Sony DCR-PC110E - can I charge the battery through USB?
    no man u can"t....in all sony brands the mini usb is meant only for data transfer...so better you go for a an ac power adopter...mail me at sharuputta@gmail.com
    Jan 26, 2009 | Sony Handycam DCR-PC110 Mini DV Digital...
    Usb streaming
    I have this camcorder. According to Sony, the DCR-DVD810 does not support USB streaming. I do believe, however, that you can use the AV port (under the lens) to stream live video.
    Oct 26, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
    Oct 05, 2008 | Sony Handycam DCR-SR42 Camcorder
    Sony handycam DCR-PC330E Mini, purchased in Tokyo, April 2004 - Was working as normal, then suddenly went 'dead' - no light showing when on charger (which had been working fine up to date), tried another...
    Apr 11, 2006 | Sony Handycam DCR-PC330E Mini DV Digital...
    Sony Handycam DCR-PC330E Mini DV Digital Camcorder Logo
    44 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
