Question about D-Link DIR-600 Router
I want to use my wifi router D-link dir-600 for internet wifi. After I set everything according to manual guide, I can detect the wifi signal, eventhough I have enable the wifi in the router.
  • D-Link Master
  • 32,281 Answers
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router. For Internet access you need to connect your DSL or cable modem to the WAN/Internet port on the D-Link.
Posted on Apr 08, 2011
Why my d link dir 600 has no wifi signal
What is colors of lights in your dlink box
skype id : johnwalker800969@gmail.com
May 07, 2014 | D-Link DIR-600L Wireless N 150 Home Cloud...
At first my d link dir 600 was working when i connect it to my wi tribe modem, after a few days the signal on my d links was lost but my wi tribe connection is still working when itry to connect aga
You will need to configure your router setting according to your ISP.
second, Contact your ISP if again and keep in mind that firmware uptodate. if problem is still remain use Linksys Home Support http://support.linksys.com/en-apac/support/linksys?icid=global-header-support-link and if use some other resources that will handle your router http://www.techsupportrouter.com/support-for-linksys-router.html
May 07, 2014 | D-Link DIR-600 Router
I purchased a D-Link Wireless N 150 Router, Dir 600L. I am unable to setup the same. Do I need a Modem also to setup this router or I can setup without a modem?
You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
Dec 24, 2012 | D-Link DIR-600 Router
Very slow wifi connection from router dlink dir-600
I had this issue also. If rebooting the router does not improve or trying a new cable between your router and internet modem, you will have to do a factory reset. You can do this by logging into the router and selecting factory reset by locating a small hole on the back of your router, insert the tip of a paper clip for about 10 seconds with he power on, and this will reset your router to factory settings and of course you will have to set-up everything from scratch.
Maybe do a firmware update at the same time.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Dec 07, 2012 | D-Link DIR-600 Router
Can't connect XBOX 360 S to D-Link DIR-600 Router
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Mar 04, 2012 | D-Link DIR-600 Router
D-Link DIR 600 connection problems
If this is the case, there is no problem with the router. the problem is with the modem.MAke sure that the cable from the modem goes into the WAN(Internet) port of the router.And also, what kind of internet are you using? is your router set up properly to work with your provider?
Is there any problems when you connect your pc to the modem directly with the cable, or does the problem occur only in the wifi connection?
Feb 18, 2012 | D-Link DIR-600 Router
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
I installed my dir 600 2days ago.. after the configuration its says "successful" but when we were trying to use the wifi,it says in our iphone that there were no internet connection.. so i tried...
Hi danielle,
I see you are connecting a mobile phone using a wireless link in you home.
on the d-link setting make sure that the Network security is turned Off and that the wireless module is turned on the D-link Router to be able to get the signal from your Iphone the network security can only be used on Laptops when turned on but on mobile phones if the netwrok security is turned on mobile phone may have issues connecting to the Router.
I hope this helps.
Have a nice day,
mvincentc
D-Link DIR-600 Router Logo
498 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
