Question about Dell Ethernet Card Network Adapter
Good day, i am using an inspiron 2200 running windows xp. someone installed a static ip address on my cp and from that day i have been unable to connect to the internet. when i go to network connections it is completely empty. there is also no network adapter visible in device manager. under other device the i see a yellow question sign beside the pci modem. i reinstalled xp yesterday with the hope that the problem with go away. i reinstalled the driver as well nothing. i am completely lost. please help
    Guru:
  • 811 Answers
Well first off know one installed a static IP your internet provider is the one that will do that for you when you get ready to go online if there are numbers in there remove them and select automatically detect settings. Most likely it is a Dynamic IP all you have to do is make sure that you have the driver installed for your card, your internet connection cable hooked up R-45 cable and once all of this is happening and lit your IP will do the rest if not then reboot the router or the modem not sure what you have they will send the proper routing goodies over the line and off you go. You just need to make sure that you are lit on your end and ready to go if for some reason nothing else works then contact your internet service provider and they will come out and make sure that you get set up. Thanks for using FixYa! John
Posted on Apr 08, 2011
Unable to wirelessly connect anymore
Click on the network icon in the task bar. Show the networks available and right click on the wireless network if it shows up. Try the 'repair' network selection.
You can also 'remove' the wireless device and re-install it. If you use the command: "ipconfig /all" it will display all the connections and their settings. Normally windows will use the auto config 192.168.xx.xx series of IP addresses if it cannot find a DHCP server to issue it an address. That should show up in the ipconfig output in the wireless network device section.
If the ipconfig does not show the wireless device, try the uninstall/re-install tactic.
If this is a PC-card [PCMCIA] that you can physically remove, power down, remove the device, power back up. Power down again, install the card, power up. Windows might then 're-find' the device and reinstall all the necessary drivers.
tom
Jan 18, 2010 | Dell Inspiron 2200 Notebook
Acquiring Network Address
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
Jan 26, 2009 | Dell Inspiron 2200 Notebook
Cannot connect to wireless
You have changed your TCP/IP settings and it cannot communicate with your wireless router.
Open the Control Panel, Click on Network Connections, then right click on Wireless Network Connection, then scroll down and click on to highlight Internet Protocol (TCP/IP), then click on the Properties button.
Select (click on) Obtain an IP address automatically
Select (click on) Obtain DNS server address automatically
Click OK and close and shutdown and reboot Windows
You should now be able to access the Internet
Jan 25, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Astra 2200 scanner won't run with Windows XP?
I have a Umax astra 2200 scanner that I was running on a Windows 98 machine and I was very happy with it. Unfortunately I now own a Dell Dimension E310 with Windows XP and I cannot get the scanner to install/operate properly. Is appears from the specs that the scanner is not compatable with Windows XP, but is there any software upgrade I can download so that I continue to use this scanner with XP?
Nov 21, 2008 | Umax Astra 2200 Flatbed Scanner
IP Address
If you click on your "start" button and then on the "run" choice you will be able to type in a command to see your IP address. The command is, ipconfig, a window will appear telling you what the machines IP address is.  Is that what you meant?
Oct 26, 2007 | Dell Inspiron 2200 Notebook
How to set a static IP address in Windows behind a Linksys Router
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
How to set a static IP address in Windows behind a WRT55AG Router
Feb 16, 2006 | Linksys WRT55AG Router
Dell Ethernet Card Network Adapter Logo
152 people viewed this question
Alun Cox
