Question about Kenmore 24032\24036 Top Load Washer
Older Style Top Loader Washing Machines
I am trying to find a diagram on how to replace the V-Belt on our washing machine.
    Genius:
  • 1,028 Answers
If the image on your posting is correct and model number 2 there is no belt washer is driven by coupler between motor and transmission it could be broke if washer drains but won't agitate or spin ..remove end caps on console by pulling up remove screws on each end of console lift console up and roll back remove clips on each corner and lift cabinet forward and off remove pump clips remove motor clips by removing screws first drop motor remove coupling and replace
Posted on Aug 07, 2008
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
How to remove ge profile top loader washing machine motor
how old is this washer i have worked on the older ones if you can send me a pic i can advise you mate
Feb 11, 2015 | GE Washing Machines
Have a calypso elite kenmore washer that will not drain. How do I get the cap to agitator off and how do I clear that line or access the drain line, this is an older top loader.
The pump is accessed from the bottom. Lean the machine back against the wall and remove the lower panel. You will likely need to replace the pump assembly. The original pump style has been changed.
Kelly
Mar 22, 2011 | Washing Machines
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
Older ge washer pump
loosen the clamp around the rubber coupling 1/4 " nut driver do not take it off completely just enough to get it off the top of the pump then remove the 3 mounting bolts on the bottom of the pump and install new
May 31, 2008 | Washing Machines
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
Final Spin Cycle Amiss
depending on the make and the model, especially if it is a top loader, try replacing the belt. when the belts get older they stretch and slip a little, just enought o cause your problem
Oct 10, 2007 | Washing Machines
Changing belt on washing machine, that broke
to change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
Aug 18, 2007 | Amana ALW540RA Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
119 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
