Dear Dell care, I have dell Pc model optiplex 360, When i open my PC, CMOS battery is very low & press F1 to enter the setup. After pressing F1 there is another error shows, error 2000 0146 in blue screen. Please give the solution. I will be available with my Mob No.+91-8018098266 or else you may contact with my
  • 384 Answers
Hi There.
You have 2 major issues on your Dell Optiplex :
  1. CMOS Battery is low - this means that you need to purchase a "motherboard/CMOS" battery and replace the one that you have. You can easily obtain this from your local electronics store.
  2. 2000 0146 (Error) - this pertains that the system has detected a possible hard drive failure and that you must run the HDST (Hard Drive Self Test) to determine if the problem can be fixed or not.
Here is the detailed guide for you to go through the blue screen error :
DELL Support
Hope this helps and Thanks for using Fixya.
Posted on Apr 08, 2011
    New Friend:
  • 104 Answers
HI Friend your batter having problem with backup
ok2ndly problem with battery driver
i solve your problem
you contact me +919041923413 OK
When booting my dell optiplex GX270 desktop,"alert! system battery low pops out, press F1 to continue or F2 for setup utility" and the screen colour chances. please, what do i do?
i think this is the problem about your cmos battery so first you change your cmos battery contained in your lap is attached with your laptop motherboard.
Sep 03, 2011 | Dell OptiPlex GX270 PC Desktop
I've changed the CMOS battery of my GX260 series desktop as it was prompting an alert as "System battery voltage low" & after that Systems IDE configuration failed performing an automatic...
Press f2 to enter the BIOS while you see the Dell start up screen. Once in there you shoudl see an option to load BIOS defaults. Load defaults. This should take care of the issue. Are you sure that you replaced it with an approved CMOS batter, You cannot use a watch battery, even though they are the same size it won't work.
Aug 01, 2011 | Dell OptiPlex GX260 PC Desktop
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
I own a Dell Optiplex GX270 Hi I get a message coming up saying ``Alert battery low voltage press F1 to continue'' on a black screen What should I do and how thanks
I think this is reffering to your cmos battery, switch off the machine and remove the side cover, have a look around for a flat cell battery, it is usually a cr2032 or similar, these batteries are cheap to buy (maybe £3 or so)the battery in question, if your not familiar with cell batteries, looks something like an oversized watch battery, maybe 20mm in diameter.
May 05, 2011 | Dell OptiPlex GX270 PC Desktop
Anytime i switch on my desktop optiplex gx270 it will alert me of my low battery voltage and should press f1 to continue or f2 to run utility setup
That warning is referring to the CMOS battery.
Powe off, unplug the machine. Open the case and look for a small round silver disck about the size of a quarter. Read the number on it and purchase a new one. (Should be something like CR2032)
Replacement is faily easy as the old one just pops out and the new one pops in.
You may get an error about Time and Date
Hit F2 to get into the BIOS and reset the time and date
Jan 03, 2011 | Dell OptiPlex GX270 PC Desktop
How to reset the CMOS on Dell GX50
Disconnect the power lead from the back of the case, open the side of the case and look for the CMOS battery, it looks like this >>>
Remove this battery for 20 minutes and the put it back, close the case, reconect the power lead and turn the machine on. You will however have to set the date and time and also set any BIOS options you want.
Dec 14, 2010 | Dell OptiPlex GX50 (GX50SC1338420) PC...
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
I Could not logon to the system
If the 2 beeps were together, then it is a check sum or memory problem. When it boots enter the bios setup(F2) and check the system time and date (located in 'Standard cmos Settings') to see if it is correct, as this is a good indicator of a flat cmos battery (large type watch battery.) If time and date is incorrect replace battery, if ok turn off pc and try re-setting the bios by putting the jumper on the 'JBAT1' terminal on the motherboard on pins 1-2 ont pins 2-3 then back onto 1-2; then boot pc back up and go back into the bios, set the date and time in 'Standard Cmos Settings' and then look on main bios menu for 'LOAD BIOS DEFAULTS' or similair If non of above works, maybe you have upgraded the memory, remove it and try again with original memory stick. Hope this is of some help
Oct 17, 2006 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
