Question about Bosch HMV9305 Microwave Oven
How does this microwave exhaust system work. The installer did not use any duct work, so is the exhaust internal somehow? There is no grill on the exterior for exhaust
    Problem Solver:
  • 16 Answers
The exhaust fan appears to intake through a louvered vent in the bottom rear of the microwave case and output through a grease filter near the top front center of the case. You may be able to see some vent holes along the top of the case though these might be obscured by the manner in which the microwave was installed. You should be able to pop off the front panel that runs above the door but you'll need to consult the owners manual for specific instuctions.
Cheers.
Posted on Apr 08, 2011
I have an GE Eterna Microwave Model Number: EMO3000HWW01 The microwave resets itself after aboout 10 seconds of use. Before it would do this and we would reset the time and date and it would work for...
It may be that the internal cooling fan is not working or the filters or air duct may be clogged, but it may also be a "noisy" magnetron.
First, check the filters. Then determine if the internal cooling fan is coming on.
I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If that is working, and you have good air flow, then see this FixYa solution.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
The microwave shuts off and will not re start until completely cooled down.
I would suspect that the magnetron is overheating and that the magnetron's thermostat is cutting power until it cools down.
It may be overheating because the internal cooling fan is not running when you're cooking.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
It is vital that the cooling fan runs, or the magnetron will soon be destroyed.
It may also be that your filter is clogged, or your exhaust duct work is clogged.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please reply directly to me with your full number from the tag on the unit so I can help you with free do-it-yourself tips or an estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I change fan position from internal to ducted exhaust?
The installation manual on the GE www site covers this in detail:
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=ITEMID&itemid=49-40453
Dec 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Need assistance installing a JVM1660BB range microwave oven. How do I attach the sleave to the duct to the microwave, while mounting the Microwave on the wall. Thanks for the specs on the microwave oven....
From page 14 of the installation instructions online here:
"Extend the house duct down to connect to
the exhaust adaptor.
"Seal exhaust duct joints using duct tape."
Jun 06, 2009 | GE JVM1660 Microwave Oven
Can't remove the vent grill
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
May 27, 2009 | Kenmore 80412 Microwave Oven
How to find rectangular to round transition adaptor
They used to sell them at sears. Its a common duct item for vents. Try home Depot.
Jan 13, 2009 | Samsung SMH7178STD Microwave Oven
Fan just circulates air instead of exhausting the air outside
The exhaust motor was not installed properly - it has to be turned 90 degrees so that the blower openings face up instead of the front. Whoever installed it didn't read the directions:)
Unfortunately, the unit will have to be taken down from the wall to correct the motor.
Dec 21, 2008 | Maytag MMV5207AAS Microwave Oven
Tappan microwave TMV151F will lose power during operation. I think around 3 or 4 minutes.
The magnetron is overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
This is usually caused when the internal cooling fan is not running or by a magnetron that is failing.
It is vital that the cooling fan runs, or the magnetron will be
destroyed.
It may also be a clogged exhaust duct or filter. Grease filters should be cleaned regularly and charcoal filters should be replaced (not cleaned) every 6-12 months.
You can refer to your owner;s manual for that info.
You can download most Maytag / Whirlpool / Tappan owner's manuals and installation instructions here.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Dec 08, 2008 | Microwave Ovens
Microwave runs and then stops, power is good.
Your test demonstrates to me that the magnetron is overheating.
This overheating can be due to the internal cooling fan's not running, a blockage in the air ducts, or just a bad magnetron.
(When I speak of the internal cooling fan, I do not mean the hood / exhaust / vent fan located behind the grille across the top.)
You'd have to consult your manual as to whether the charcoal filter should be used and how and whether it affects cooling.
Also, the charcoal filter cannot be cleaned,. It must be replaced when dirty or at intervals suggested by your manual.
If you do not have your owner's manual, please reply back with your brand and model number so we can help you.
Please reply back here if you still need help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | Microwave Ovens
Noise of microwave exhaust fan
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
Mar 25, 2008 | Microwave Ovens
Bosch HMV9305 Microwave Oven Logo
240 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
