Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
I have a Model # CH25S, SPEC # 68501 and SERIAL # 3222612881. It is sitting inside of a boat in south Louisiana, we call them mudboats. The engine is at 18 degree pitch. Specs say I can operate this engine with a 25 degree pitch or less. I just purchased this boat. I have no idea of the engine's past. I went through the carb and cleaned parts, and set the float to manufacture's specs. (22mm measured from the float bottom to the air horn casting) When I try to start the engine, the carb sneezes, a lot of black smoke comes from the exhaust and an occasional back fire and fuel shooting out of the top of the carb. I however did get it started twice, but had to keep it at full throttle to run. I'm not sure what to check next. Im thinking because of the pitch of the engine, the floats have to be adjusted, if so, how much?? If not the floats, can you please give me a little insight on what to door look for next. It's definitly getting too much fuel. Oh, it's a keihin carb with the number 22 stamped on the inside by the choke flap. It's a very simple single barrel carb.
5 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: kohler motor starts then carb loads up with gas
If the engine is running rough then this could mean that you have weak spark or valve adjustment. When an engine runs rough it will not burn all the fuel, which will create excess fuel in the air cleaner housing. Also, make sure the the float is closing in the carberator.
Posted on May 07, 2009
SOURCE: kohler k582 runs poorly at operating speed.
ALWAYS CHECK THE POINTS!!! 20 years operating this engine and you'd think I would know better. The points were severely pitted. Spec said .020 but actual is .013. The cold weather had me suspecting a carb problem. DOH!
Posted on Jan 14, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have a Kohler RV
it sounds like that, I would look at the needle valve to make sure opening. What I would do is remove the bowl and let gas flow thru it, then push up on the float valve and release to see if you get another stream of gas. What you can try also because I think there is gum(from stale gas) is running with the choke partially on till it starts to flood out and the open choke and see if continues to run. I don't know how extensive you mean when you say "cleaned" the carb but you might have to again with a good carb cleaner or find a soak for it.
Posted on Jun 26, 2011
SOURCE: I have a Kohler generator
Check the genset controller for a fault, low oil psi, no output voltage, overspeed, overcrank / no crank disconnect signal / starter staying engaged, high engine temp.
Posted on Jul 04, 2011
Have evinrude outboard serial number 1591802140. What is model number and year?
Hey Jan,
The model number/serial number should be on plate attached to the engine mount...You need the model number to determine year.
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 25, 2017 | Boating
What year and model is mariner 75 serial number 9502368
Hey Arthur,
This serial number does not show up..???Please look for more numbers on any plate or freeze plug..
These guys can help.. need more info though...
Jun 20, 2017 | Boating
Hi, have a mariner 75hp outboard serial number 9502368. Can you please identify year and model so I can order spares
Hey Arthur,
These guys will take care of you,,, that serial number doesn't satisfy the rewquirements for a search...? They will need more info.. more numbers on any plate..freeze plug..look around the outside of the engine carefully..
Jun 19, 2017 | Boating
How to find the model number for my johnson outboard from serial number
On the port side where the outboard attaches to the boat there is a plate that has your engine model and serial number.
May 07, 2017 | Johnson Boating
Do you have a picture of interior carburetor?
carbs are simple the have a pin, a float ,and a seat,, all parts have to be straight and clean and not cracked the seat rubber must be smooth the float must float, there is no adjustment.
Oct 01, 2014 | Garden
Need wiring sch for7CCKMR61 spec 140291 serial 326977
I can maybe help with that, as this is an old post, if you still need it let me know
Aug 31, 2012 | Kohler Electrical Supplies
Yes i have a dixie chopper i need to order a part in my town but my # has off of my dixie i have the model # x2303 serial # 7069987 i need the model # and the spec# to order my part i have the engine #...
Your machine came with a Generac engine model gtv760 Spec 005058-X
The engine serial number that you provided belongs to a Kohler Model CV23 Spec 75617
Aug 19, 2011 | Dixie Toys
My 190cc, no primw, no choke engine stalls after a
Clean the carb bowl out. Check for water in fuel. While the carb is open check the float for obstructions and good volume of flow.
Make sure the float height is within spec. You will need to go the BS website and get this spec with your motors model and serial number. Normally floats are good when they sit level at the point the fuel stops flowing.
Good luck and be careful!
Jul 22, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
What engine should fit my 28´bayliner boat
Yes there is. Saw one at a boat show and I believe it was also Swedish. You may want to look for used replacements on the web. I do not know where you live, but there are boats on the Great lakes with low hours because of the short boating season. There are also victims of hurricanes with good engines down South.
Jun 18, 2009 | Boating
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
390 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
