Question about Cub Cadet Garden
I would like to see a repair manual for a 20hp kohler engine so I could learn how to check the timing
  • 3,740 Answers
I can provide you with the manual you need via a web link. I need to know your engine MODEL number (Not rated HP) The service manuals go by model number only so the HP rating is of little help to find the manual. For example this is one link:
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2574_a.pdf Timing marks are on page 125 of the manual link above. Let me know your engine number and I will get you the manual. Just don't rate the post until AFTER you have the manual you need.
Thanks for choosing FixYa,
Kelly
Posted on Apr 08, 2011
I have a 20hp kohler engine model no.sv600 and I need the timing marks on the engine can you help.
Posted on Aug 14, 2011
What is a bad pressure relief valve in the head of a 20hp kohler engine
some of the larger hp (over 10) small engines use a small pressure unloader valve in the piston area , this is usually activated by oil pressure (as they have oil pumps and don't rely on splash system ) the symptom of the unloader valve not working is the engine is laboring to start ,sometimes might not even do so, but if one turns crankshaft back one half rev. it will start as normal , unfortunately most of the times this valve is not easy to access without disassembling the engine , most of the times I fix them I find it clogged with grime from lack of scheduled oil changes and grime seems to collect right in this area , these same people allways ask (after they get the bill) what tells me the oil needs changed , I tell them that as soon as you see the oil change to a darker color then its time !
Nov 20, 2015 | Cub Cadet Riding Lawn Garden Zero Turn...
The cluche wont ingage crafeman cv491s
  1. Free Kohler Service Manual Downloads : Kohler Engines ...
    https://www.kohler-engine-parts.opeengines.com/.../free-kohler-service-...Kohler Engines and Kohler Engine Parts Store Free Kohler Service Manual Downloads - Listed below are Kohler service repair manual in Adobe PDF format ...
Jul 15, 2015 | Cars & Trucks
20hp kohler horizontal engine will make loud metal on metal chirping noise coming from the crank case after running for a period of time, seems like it could be an oil circulation problem. usually when I...
the chirping you hear is probably from a worn cam or valve lifter.
usually these engines use an oil slinger to throw oil around the crank case.
if the oil gets too low parts will wear away faster.
sorry to say but your engine has probably had it and is due for a rebuild.
always keep the oil at sufficient level and change it regularly
Sep 12, 2013 | Kohler Electrical Supplies
Kohler backfires
This is a timing issue. Check the flywheel to make sure that it is not loose and that the woodruff key is still present.
May 25, 2013 | Toro ENGINE - 20HP KOHLER Part 93-1169
How many hours of use can I expect to get from this mower?
the more you do maint on it the longer you will get oil changes filters shape blades help engine load do you ever take off the top cover and clean the cooling fins?do you climb hills?use it to pull loads arouund the yard?but the 20hp kohler engine has had problems cracking the block on top of the engine my mower has a 22hp kohler with 2236hrs on it starting to get tired
Jun 07, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Have a brand new Husqvana with a 20hp Kohler V twin engine. Is it necessary to run the engine in? Nothing in the manuals about running in.
it doesn't hurt to ease it operation wise into service,but for sure do what the owners manual says to protect your warranty,and change the break-in oil soon to remove any machine shavings from the unit during the engine manufacture process
Mar 05, 2010 | Garden
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
351 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
