Question about FUJIFILM FinePix S800 Digital Camera
Fuji finepix s800 lens error message - FUJIFILM FinePix S800 Digital Camera
    President:
  • 287 Answers
Hello and welcome!
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
The following solutions are there by which you may Fix the lens error
  • Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
  • If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed
  • Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in
  • Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit
  • Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to out the particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly
if further assistance required, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
Posted on Apr 08, 2011
Fuji fine pix s800 - have to use view finder to
Press the button marked "evf". That should move the image to the big LCD for shooting.
Aug 10, 2009 | Fuji FinePix S8000fd Digital Camera
My Fujifilm FinePix F20 digital camera gives me a zoom error message and the lens does not open when I power up
problem on lense .remove ur lens on ur camera and cheak the motorgears which are supporting to move lense
Jul 11, 2009 | Fuji FinePix F20 Digital Camera
ZOOM ERROR ON FUJI FINEPIX J10
Mine did this too, and the lens cover only opened half way. I used a cotton wool bud to push the lens cover back and held it back until the lens clicked into place, turned it off and on and then it was fine
Jan 13, 2009 | Fuji FinePix 2650 Digital Camera
Disk
Honestly I don't know much about the A820 and S800. But when I checked Fuji's website I saw the manual for the A820 and the Cd in the manual has the KA. This website contains the info on the A820.
http://www.fujifilmusa.com/products/digital_cameras/digital_technical_support/index.html
I didnot have time to search for the S800. But my gues is that the CX is for the S800.
Jul 18, 2008 | Fuji FinePix S5700 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
Zoom error message
The higher end fuji's are good cameras. The A345 and A350 are a piece of crap. Low end Walmart cameras.
Oct 29, 2007 | Fuji FinePix A345 Digital Camera
FUJIFILM FinePix S800 Digital Camera Logo
87 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
