Question about Zanussi TC7114W Electric Dryer
How do u fit the belt on a tc7103s on to the motor
Drive belt requires to be replaced. Have got correct one, however, seems too tight to fit round wheel and pulley. Access is only through top of machine so this does not help. Is there a tool or technique...
Hello
The motor has a tension bolt that you need to loosen befor you can fit the belt. once the belt is fitted you can retention the motor.
Thanks
Jun 11, 2011 | Washing Machines
Timeing belt broke have replaced now not fireing
You either have the belt 180 degrees off. So you have to take belt off and turn crank only (slowly) around once to its mark again, but first you need to go to a website that lists motors that are called "interference fit" engines. (Think Gates belt co. has a list) If your motor is an interference fit then when belt broke the motor is trashed. Interference fit means that pistons can hit valves if the belt breaks. That is why they tell you to replace the timing belt before too long. Also if motor is interference fit when you try and turn crank go slow because you may bump into valve.
Apr 04, 2011 | 1993 Geo Storm
I'm trying to replace the belt on a Hotpoint VTD00P tumble dryer. I've successfully removed the sides and front, fitted the replacement belt around the drum but just can't get it to stretch enough to fit...
There is a tool available, but it is not worth the expense of buying it for a one off repair.
Best way to do it is to geta long piece of steel rod, or a long screwdriver, and place it behind the belt, lever the belt down and over the motor pulley, it is difficult, so persist with it and you should get the belt on.
If you can slacken the front securing screw holding the motor, down this will give you a bit more leeway to fit the belt.
Again it is difficult, but I have done it this way on every occasion I have fitted a new belt.
Nov 27, 2010 | Dryers
Replace belt on Hotpoint Aquarius WM31 washing
Hi.
Remove top cover of washer.
Remove rear access panel.
Slacken off the motor fixing bolts, and pull motor towards drum top.
Fit belt round motor pulley first, and then feed it round the drum pulley from the rear of the washer.
Tighten motor bolts just enough to hold motor steady, and pull motor towardsa cabinet side to tension belt, it needs to be farly tight.
Then tighten motor bolts securely.
Fit back top and rear covers.
Apr 05, 2010 | Hotpoint Washing Machines
How do I fit my new belt on a Meile W864 washing machine
the beltshould have a number on it and u can call any belt place or an appliance place and give them that number and they should be able to get 1 pretty easily
Feb 26, 2010 | Washing Machines
Changed belt on zanussi tc 482 w
heater in Zanussi tc7103s not working . stats and element ok. cant locate reset button
Jan 08, 2009 | Zanussi TC7114W Electric Dryer
Cant get new drive belt to fit washing machine. right one but cant get it to stretch enough to fit from drum wheel to motor
this is a common problem as nowadays stretchy belts are used in order to avoid motor adjustment.
fitting requires some brute force. the way i do it is to put the belt on the motor pulley then start it as much as i can on the drum pulley. turn the drum pulley keeping force sideways to push the belt on and as you turn, the belt will go on
Oct 21, 2008 | Hoover Washing Machines
How to get back off to put belt on samsung b1445s washing machine
See if the motor has adjustment , ie a slotted fixing hole, slacken the fixing bolts slightly and motor may move up and down to give adjustment, put the belt on and then put some tension on the belt once fitted by moving the motor down and tightening the motor bolts at the same time.
Or if no adjustment put the belt on the motor spindle first and then the drum by turning the drum as the belt is eased onto it.
Apr 08, 2008 | Washing Machines
Fitting a dryer belt
depends on dryer but remove are lift the top up remove front panel slide new belt over drum with rib part belt toward drumaround motor and pulley
Feb 27, 2008 | Dryers
Belt fitting for a WF000 hotpoint washer?
It should go around 2 wheels; one is the pulley of the motor, where there is a good groove. The other goes around the tub wheel which is big one. First fit to the motor wheel then fit to one side of this big wheel & turn the wheel to engage it gently. The belt should have a "give" of only half an inch, or it will be too loose or too tight.
If helped pl rate.........
Dec 28, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Zanussi TC7114W Electric Dryer Logo
53 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
