Question about Sony KP-51HW40 51" Rear Projection Television
Picture with red 3-D effect
All of a sudden my 4 year old Sony 52" rear projection tv produced a 3-D like effect with the red color. I adjusted the red inside but all it did was make it blurry and the other direction made it clear, but still off to the right. I ended up covering up the red bulb with a rag, and now the picture is perfect but everything is greenish/bluish. I have no idea what I am looking at inside the tv, but would rather fix it than buy a new tv.
  • vburks2000 Aug 18, 2008
    Good Day Friends, Got up today to watch tv and my set looks like a 3d unit all colors converge any ideas on what this is the unit is a sony kp-51hw40 thanks for any help
  • 10,594 Answers
IC8001, STK392-560 seems defective, its convergence output IC.
Posted on Aug 06, 2008
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Odd picture....
Yes, your convergence is off. There is a function in the menu for adjusting these propoerties. It is supposed to be done monthly but rarley is. If it is ten years old or more, the cooling fluid in the projection tubes can get low, causing fish bowl effect. Not a cheap job and time intense. Try adjusting the convergence first. It gives you three screens to aling each color then save. Good luck!
Jul 25, 2009 | Televison & Video
Picture warped and colors not lining up
Good Day petepath7;
With separation of colors it sounds like the convergence IC's have failed., but first try unplugging TV from a/c power for 4-5 minutes then plug back in, if no fix see previous.l
Jun 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
2 images
you have possibly 2 faults /one may be convergence ,the other is screen adjustment set to high(red).
Sep 06, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
129 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
