Question about Philips 43PP9202 43" Rear Projection Television
I HAVE 43PP8421 PHILIPS HD TV MONITOR, IT WAS FINE BUT NOW IS NOT, I GIVE POWER I RECEIVES, CLICK SOUND COME, THEN A DIM SOUND COME 1 C/S RATE, NO PICTURE, NO OTHER SOUND, I AM WORRY, I CHECKED MAIN POWER FUSES, JUMPERS BUT THEY R OK, PLEASE HELP ME TO GET IT WORKING? THANKS
SOURCE: No power
Brand, and size please? Most problems come from either the power supply, or deflection circuits.
Posted on May 27, 2007
  • 1153 Answers
SOURCE: tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
Posted on Aug 25, 2007
ctf1800
  • 4402 Answers
SOURCE: philips rear projection tv 43pp8545 no picture sound ok
do you get a blinking read light?
Posted on Dec 14, 2007
  • 579 Answers
SOURCE: Philips CRT Rear-Projection TV 64P8342
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Most common death mode)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Posted on Feb 11, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips 51PW9363-17F - No picture but has sound
Common problem. Goto www.TvRepairKits.com and to get their "No video, audio works " kit.
Posted on Mar 15, 2009
37PF9731D/10 - when turned on the tv power light remains green but no picture or sound. Just a clicking sound - like it does normally when swiching on from being on standbay. It reapts the attempt to turn...
The clicking sound is from the main power supply relay being turning on and off, it is driven by hte main board and it gets the power from the standby power supply board.
You need to check the main powwer supply board and the standby power supply board voltages.
Check the resistor in the main power supply board also
Please see my pictures here: http://s807.photobucket.com/albums/yy352/budm/Philips/Philips%2037PF9631D_37/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 16, 2011 | Philips 37PF9731D 37 in. HD-Ready LCD...
After installing the ASUS EAH5450 my computer turns on and runs fine on my desktop monitor. However, I've hooked up a HDMI cable to my Sharp Aquos and the tv says it's receiving an incompatible...
The easiest thing to try is change the screen resolution before connecting via HDMI. The process is a little different depending on what operating system you're using.
For Windows Vista/Windows 7: 1. Right click on your desktop and select "Screen Resolution" 2. Slide the bar to change the resolution to either 1024x768 or 1280x1024. 3. Click apply.
For Windows XP: 1. Right click on your desktop and select "Properties" 2. Click on the tab to the far right that says "Settings" 3. Under Screen Resolution, slide the bar to change the resolution to either 1024x768 or 1280x1024. 4. Click apply.
Either of these resolutions should at least give you picture when you reconnect with HDMI. Once you get a picture, repeat these steps and gradually move the slider higher to get a better resolution picture. If you receive the incompatible signal message again, just wait 15 seconds and the previous setting will be restored.
If this doesn't work, you may also have to adjust the screen refresh rate. From the same window that has the screen resolution adjustment bar, click the link or button that says "Advanced." The second tab, "Monitor," has a drop-down menu to adjust the screen refresh rate. Depending on your HDTV, the most common setting for this could be 60 Hz, 70 Hz, or 120 Hz. If none of those values work for you, you should check the manual that came with your TV to check what the proper resolution and refresh rate should be for your computer connection.
Jun 10, 2011 | ASUS EAH5450 SILENTDI1GD2 graphics adapter...
My Philips 50" plasma screen won't work. the sound
It can be the power supply, Z-sustain boards failures due to bad caps, blown fuses. Yopu should alos check the Y-SUSTAIN board also.
You can see what the boards look like here:
http://www.shopjimmy.com/catalogsearch/result/?q=Philips+50PF9631D+
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Please post back what you find.
Please leave rating if it helps.
Jan 21, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My primary monitor is a TV set with 100hz refresh rate, but ccc give me only ATI philips FTV with 60hz. is there special drivers
Open CCC, go to monitor properties/attributes, untick use extended display identification data and select the refresh rate manually.
Jan 06, 2011 | ASUS ATI RADEON HD 5450PCI EXPRESS21DDR3...
My tv model is 43pp8421. when i turn it on, it has a clicking sound and no picture and sound
hello i hope i can help you. may i please ask you. is the clicking sound like a burr?? or it just wont start? if you have a multimeter check the fuse check to see if a break on the mains cable if ok? if ok open tv up and do a voltage check to see if the tv is receiving power? please check the speaker.S? also check the switch. if power is going in but no power on the other side of switch the switch is faulty also check the volume control.
May 04, 2009 | Philips 43P8341 43" Rear Projection...
NO POWER COMES ON THE TV 43PP8421 PHILIPS
It sounds like the main filter board is defective as thats the power supply board for your model.
Mar 25, 2009 | Philips 43PP9202 43" Rear Projection...
Not sure how to connect other devices
Unfortunately, the Westinghouse monitor has a bunch of inputs available, but completely lacks the audio output connection you need that would make life simple. Your Philips HTS only a single auxiliary audio input, but it does offer video and audio output connections to a monitor.
About the only solution I see available is to buy an A/V selector switch (available from Radio Shack and probably stores like Best Buy). Run the audio connections from the HD receiver and XBox through it, and send the output from the selector switch to the auxiliary audio input on the HTS6500. (You could use RCA Y-adapters to connect the audio to the monitor as well as to the selector switch if you really want to.) Send the video from these sources directly to the monitor.
You would need to select the source on the monitor, A/V switch and HTS to get the result you want, but it would be workable. (Now, why didn't Westinghouse simply include a set of audio output jacks with all those sources available?)
If this solution has gotten you going, please take a moment to rate it. And thanks for asking here!
Feb 25, 2009 | Philips HTS-6500/37 System
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 43PP9202 43" Rear Projection Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
