Question about LG DLE0332 Gas Dryer
The dryer acts like it is working, but does not get hot. blows warm air. After the cycle ends, we have to turn the dryer on several times to get the clothes to dry.
  • LG Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 08, 2011
2 Suggested Answers
  • 77 Answers
SOURCE: Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
Posted on May 12, 2009
My dryer does not blow hot and will not shut off and no digital reading will display.
Hello Bryan;
My name is Peter. I am a retired field service appliance technician.
So, here are the probable causes:
1.) The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may be plugged up or not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft. Check the blower hot air discharge manifold for blockage.
2a.) If the dryer won't stop, the gas valve solenoid coils might be defective. Over time these coils will fail, causing the burner to run intermittently. If the dryer is not heating properly it may not stop. Replace the coils as a set.
2.b) The heating element warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element isn't working - which greatly increases the drying time. Check the heating element for continuity.
3.) Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
4.) Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or shorted
5.) If the dryer won't stop, check the high limit thermostat. If defective, the high limit thermostat can turn off the heat prematurely, lengthening the time it takes to dry a full load. This is not common.
6.) The cycling thermostat regulates the temperature of the air in the dryer. If the dryer won't stop, it may be caused by a defective cycling thermostat turning off the heat too early. This is not common.
7.) The thermistor senses the temperature of the air in the dryer and cycles the heat on and off. If the dryer won't stop, the thermistor may be defective. This is not common.
Nov 16, 2014 | Dryers
Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
Aug 21, 2007 | Whirlpool GGW9200L Gas Dryer
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
Heats up but takes several cycles to get clothes dryer
Check for a restriction in your exhaust vent. not just behind the machine but all the way to the outside vent,should have good warm airflow at outside vent. With no good air flow you have no way to get rid of the moisture. and all you will end up with is warm moist clothes. this can happen slowley happen over time and next thing you know it takes several cycles to dry the clothes .it cost a lot to dry them this way
Aug 08, 2010 | Amana NED5400TQ Electric Dryer
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Mar 10, 2010 | Kenmore 63942 Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Dryer does not get hot
pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
Jul 20, 2007 | LG DLE0332 Gas Dryer
LG DLE0332 Gas Dryer Logo
49 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
