Question about Welding Tools
I got a miller legend it runs but got no high idle at start up or when trying to weld. does supply power to 15amp outlet which typically causes machine to high idle but it wont.produces minimal current to lead and no electric to 4 20amp outlets
4 Suggested Answers
  • 7 Answers
SOURCE: Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Posted on Feb 04, 2009
ok boy your welder have a riostathic control check contacts of your control maybe have dirt or grease
Posted on Mar 01, 2009
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
250. What causes it to run roughly and lose RPM?
The Miller 212 has a 60% duty cycle. So for every ten minutes of welding the machine is designed to weld for 6 min and cool down for 4 min.
Sep 02, 2015 | Miller Welding Tools
I have a miller bobcat 225 is lower power while welding, any idea?
First off, check all of your welding cables to make sure they're in good shape, then check for tight cable connections. Is your machine staying at low idle speed while trying to weld? If so, Switch the idle select into the 'weld' position and make sure the high RPM's initiate. Try welding again. Better? Could be a number of things, if not.
Dec 12, 2014 | Bobcat Miller 225 Welder Generator 907209...
Miller syncrowave 300 no power light and no weld power however have 480v input fan runs and can hear gas start when foot petal pushed
The first thing to check would be to see if you have open circuit voltage at the weld output terminals when you push the pedal. Make sure the high frequency is off if you are going to to check with a multimeter. After that if you do have OCV but no high frequency to start the arc, try it in start and in continuous. When you put it in continuous it bypasses a control relay. Also check the HF points to make sure they are clean and gapped to about ten thousandths.
Mar 05, 2014 | Hobart Handler 140 Mig Welder
My new Miller Bobcat has low amperage on 120 volt outlet.
Increase your idle setting on the 1/8" threaded rod protruding to the left of the carburetor until V= 125. Then run your drill. Actuating the drill should call the throttle solenoid to open up to produce more power.
May 12, 2010 | Miller Electric Manufacturing Electric...
I have a Miller 225G plus. it idles up good and
Take off shroud, look at where the positive lead hooks into the transformer. You may find that the wire has melted, If you are lucky, you can loop it tnough to make a fresh connection. (also check the negitive)
Dec 09, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
Miller bobcat 250 welder with kohler lp gas engine won't idle properly any adjustments for air/fuel mix?
Make sure that the idle is set at 40Hz. You do this by placing a frequncy meter on one of the 120Vac outlets. If frequency is low, the engine will run rough at idle. There is a 3/8 nut next to carberator that needs to be turned to the right to increase the idle speed.
May 13, 2009 | Miller Welding Tools
Miller bobcat 225g plus welding problem
May 06, 2009 | Miller Welding Tools
Jan 23, 2009 | Welding Tools
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
