While receiving fax i m getting comm error 242
  • Brian Manuel Apr 08, 2011
    Have you tried other locations? could be that fax mach. was out of paper or memry on the other end. If so then state the model of the thing,each model has there own error code system.
  • 2,460 Answers
My crystal ball has been broken ever since the start of NCAA March madness :-)
Here's a thought http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&lc=en&dlc=en#Error242
Carl, using best guess without a fax machine make and model
Posted on Apr 08, 2011
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
I keep getting comm error 242 when people are faxing to me
The "sender's" fax machine is attempting to RECEIVE a fax. This happens because they don't have the document fully inserted into the scanner before dialing. (According to HP's error code listing for "comm error 242" - http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=buu02549) This is not a problem of a bad connection. Bad line condition codes are 223, 224 and most of the codes starting with 23.
Apr 28, 2010 | HP LaserJet 3050 Printer
Fax reception fails
Hello Dear,
The error message 242 appears in HP Photomart C7180, when the remote machine (the fax machine at Fax Sender side), is having problem, and it is trying to receive fax instead of sending. So actually both these machines try to receive the fax at the same time.
On many fax machines it is possible to accediently initiate the fax reception when:
1. The paper is not loaded in the machine
2. Or The paper is not correctly loaded.
You may contact the fax sender to check the above things. There is absolutely no problem with machine at your end.
Thanks
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Brother FAX 8360P comm.error
It could be line noise on the phone.., which allows phones to work ok, but causes problems with faxes. See this document from the brother website concerning comm.error:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000067/faq000167_000.html?reg=us&c=ca&lang=en&prod=fax2800_us&Cat=11
Would recommend having the phone company run a line check to make sure the phone line is clean of interference !
Jan 21, 2009 | Brother FAX-8360P Plain Paper Laser
Comms error message
check your dsl cable get dial tone or not.
Nov 12, 2008 | Canon L120 Fax Laser Printer
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
234 people viewed this question
jasbo
jasbo
