Question about Lands Phones
Hi have a phone bush magro i cant get the handset to register
  • 3 Answers
SOURCE: bought new phones kxtga110ex and want to register handset from kxa141es
I can send you a manual. Just email me on gorbuz@yahoo.com
Posted on Nov 04, 2008
bunnydawg
  • 5158 Answers
SOURCE: register handset
drop each phone one at a time into the base... not the charger.. the main base... you will notice the charging light flicker... move on to the next phone... they should all be registered when you are done
Robert
Please take a moment to rate this solution thanks
Posted on Feb 05, 2009
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
SOURCE: uniden 2080
I have same problem
Posted on Nov 19, 2009
kerguney
  • 577 Answers
SOURCE: phone will not register with base
Would you try this procedure:-
First on the base station..press and hold paging/register key for 3 seconds
Than on the hand unit select function key and open "MENU"
select "SETTING" from menu and confirm (Ok)
Selecect "HANDSET" and confirm
Than select" REGISTER" and confirm
than enter "0000" as pin and confirm..
it will flash and it detects the base.
Take care..
Posted on Jul 09, 2010
I cant dial out it says register HS i am not familiar with the procedure.
When you reset a handset (or if you buy a new one1, that handset displays a Handset Not Registered message. If you see this message on a handset, you need to register it to a base before you can use it.
Registering a handset
Does the handset fit in the base cradle?
Yes
No
Place the handset in the base.
The display should say Handset Registering.
1. On the base, open the menu and select Register Handset. The display should say Handset Registering.
2. On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
In about 30 seconds, the handset display should say Registration Complete. Press TALK ( )/FLASh and make sure you get a dial tone. page29image32024
27
If...
Try...
- you don't hear a dial tone- the display says Registration Failed
Making sure the handset is fully charged, then start over at step 1.
To register a handset to a different base, see the section "Expanding Your phone" in the user's guide for the other base.
Mar 18, 2014 | Uniden DECT 6.0 Cordless Phone ID
Registration
Hi Tom
Can you please tell me what the model of the expansion phone. I may be able to research anf find you the correct procedure for resistering a new address number to the phone.
Thank you
Greg
Nov 03, 2007 | Motorola Mobility MD761 Cordless Phone
Bought a spare 3111 handset and cant connect it to my base. it looks as if it was connected to another base at one time. screen just says "connecting..." and there is nothing I can do to clear...
The handset must be registered to the base unit if the system has multiple handset ability, the manual will tell how to register the handset. If the system is a two handset system then only two handsets can be registered.
Dec 08, 2010 | Vtech Cordless 6041 Phone
Uniden 2080
I have same problem
Nov 16, 2009 | Lands Phones
A busy signal
Hi Kevin,
Sorry for being off line so long. If you have not fixed the problem already, I would try de-registering the handset 3 (from both the base and handset), then re-register it, it should re-register as HS 3, unless 1 and 2 are vacant. If that does not do it, de-register just the handset (not at the base), then re-register it to the base, it will grab the next sequencial intercom number. If it is still failing, then the handset is most likely defective. As a last resort, you can try initializing the handset and the base. Let me know how it goes. CG
Apr 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
Handset says unregistered
The manual says that to register it needs to be completely powered off and then restarted. I unplugged my battery and then plugged it bacdk up.
Feb 28, 2008 | Uniden Cordless Phone
PROBLEMS with phone
Had the same issue. I have two units each with a handset, and one handset went to "out of range" status and stayed that way even after recharging. I tried to register it with that base and no luck. I then tried to register it with the other base and it worked. Then I tried to "swap" the handsets and no luck - it seems that the registration process on the one unit is toast so now I can only use the handsets with one of my two base units.
Oct 22, 2007 | Motorola Mobility MD7091 Cordless Phone
Lands Phones Logo
101 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
