Question about Olympus Cameras
I am from the philippines and i own an olympus e 3 dslr. when i use it, upon being turned on, it will focus just as quikly as before but the shutter would not 'click' or function. do you think the shutter mechanism is busted? i bought this camera 3 years ago and used it for birding. i did not expect the shutter to give out so soon! if the shutter is busted, where in the philippines can i have it fixed if it can still be fixed? thanks. segfredo r. serrano
    Brigadier General:
  • 11,967 Answers
Remove the lens and fire off a few shots. Does everything work properly? Put the lens back on and try it again. If it still won't work, then I suggest you go to the Olympus website, click on support, and e-mail one of their technicians about your problem. They can direct you from there as to wether you need to send it in for service and where.
Posted on Apr 08, 2011
Cannon T6 DSLR kit how it works
You look through the lens at the subject.
If the lens is set to autofocus, it will focus when you use the shutter button.
Aug 02, 2017 | Cannon Cameras
Sometimes shutter release button is very slow, other times it is fine. Just began happening. Do you have any idea what the problem may be
On page 28 of the advanced features manual from your camera, it explains how AF works. Focusing should happen while you press the shutter realise button half way down. Depending of the light, contrast and subject this can take from half a second to sometimes twice or three times as long. When in focus, you hear a beep and see a green light on the display. Then you can make the composition (or fine tune the outline of your picture) and then you press the button fully. The compact camera does work different from a DSLR. If you are user to a DSLR, you have to learn the compact, because it needs more time to focus, because the focus system is completely different.
Mar 22, 2014 | Panasonic Lumix DMC ZS19K 141 Megapixel...
My Sony a200 DSLR is vibrating and making a loud noise HELP!
Sounds like the shutter is jammed. I would get it serviced at a Sony Service Centre.
May 28, 2017 | Cameras
How to use olympus e520 in less light
The first answer is from some one who obviously is not familiar with Olympus (and many other brands of DSLRs) or he would know that many lenses do not have manual focus scales to use. Olympus Standard Grade lenses do not include a focusing distance scale.
The more important issues for you are determining -
1) Are you trying to use "Live View" to focus?
If so you are using a less sensitive auto focus mode. One of the benefits of using a DSLR is that it can use more sensitive auto-focus systems than Point
Sep 05, 2010 | Olympus Evolt E510 Digital Camera
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
Olympus om-2 cvamera lenses
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
Apr 06, 2009 | Olympus FE-330 Digital Camera
Blurred focusing as soon as turned on
Dear Hokiefootball,
Merry Christmas to you,
Have you Check your Macro and SuperMacro setting whether its turn on or not. The function is for closed up shooting. The sound is from the motorized elements and mechanism in the camera for focusing and shutter adjustment, it is normal. Direct your camera to any object and try to press half-shutter until the target become green. Good Luck
Dec 25, 2008 | Olympus Stylus 1010 Digital Camera
Shutter Lag
Card speed won't interfere with shutter lag. The lag is much less (near non-existent) if you pre-focus. Or use manual focus with small enough aperture to get lots of depth of field. Make sure your kids are in the focus zone and just snap away.
Sep 13, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Cameras Logo
32 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
