Question about Omron Healthcare Omron H3cr-a-ac100-240v Timer 0.05s-600h Dpdt 5a250vac
I use Omron H3CR 8pin to my CCTV in my car. I use pin 2 for ground,pin 7 for ignition, pin 4&5 for direct current from battery and pin 8 to +ve CCTV. My problem is when I off the engine the timer is not function (no power indicator),but the CCTV continues on (CCTV suppose off when timer is over); but when I switch engine, the timer is on (power indicator on), I change by not using the ignition wire,(which mean I connect pin 7 along with the pin 4 & 5) the power indication work well & after engine off & the timer setting is over,the out indication is appear,but the problem is, if I start engine again,the CCTV is not on & after i pull out the timer & reinsert it again,then only everything goes well. I need to know how to make sure that after I stop the engine, the CCTV will off after the timer is over but when I start the engine back the timer should automatic show power indicator on and the CCTV work.Please assist
I don't have exact schematic for your 8-pin timer.
Use multimeter read ohms and voltage from pin socket to pin socket.
Use multimeter set to ohms to read continuity of pins on timer.
Pin timer relays have NO NC pins.
Some pins are Normally Open (no current flows until timer turns on)
The other pins are Normally Closed (current flows until timer turns on, and when timer turns on, this circuit turns off)
Posted on Apr 08, 2011
Pinout for 8pin din plug
Hi looking at female 8 pin din with the groove at bottom this is No 8 going clockwise to the left is pin 6 next is No 1 then 4 - 2 - 5 - 3 - 7. ..Hope this helps..
Jan 27, 2016 | JVC Audio Players & Recorders
11 PIN OMRON H3CR-A TIMER CIRCUIT
i found a wiring diagram using google search term h3cr-a use images tab 11 is a common 8 is nc 9 is no
Oct 15, 2013 | Hardware & Accessories
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I need the total wiring diagram for camera [8pin rj11]
8 pin RJ45 (8P8C) male connector
at the camera output
LG LVC-CY100NM Color Security Camera with 8-pin RJ45 (and other cameras for the LSP-M1017M Dual Quad Observation Systems by LG)
Pin
Number Pin
Name Description 8 SPK Speaker (Hot) 7 VID Video Out 6 GRN Ground 5 SPK- Speaker (cold) 4 AO Audio Out/Alarm Out 3 VDC 12VDC 2 N/C RS-485- 1 N/C RS-485+ Note: Pin numbers are labled backwards in the manual (corrected above).
The camera is adaptable for use in any composite video application with the use of a balun.
on the output. I had noise-less video and clean audio across a 350 foot run of cat 5e.
Jan 29, 2013 | LG LVCCy100NM Color Security Camera with...
H3CR 11 pin
1) When oven turns ON, Power flows between the timer and the oven.
http://waterheatertimer.org/How-to-wire-pin-timers.html
2) For example the oven might be connected to pins 8 and 1.
Connect a light bulb to terminals 8 and 1.
http://waterheatertimer.org/images/10-pin-wiring-350.jpg
3) Since the H3CR timer is rated max 16 amps, I suspect the timer controls a contactor and is not directly attached to heavy oven wires.
So if max amp load on timer is 16 amps, then it is safe to add light bulb wire without line fuse between timer and light.
http://waterheatertimer.org/Fuseholder.html
4) Add comment and say what you are doing.
Jan 21, 2013 | Hardware & Accessories
Omron H3ca
Delay timers usually start with a push button, or momentary impulse of power. The delay begins when the impulse power ends.
H3CR-A is solid state multi-functional pin timer available in 8-pin and 11-pin models.
11 pin has six modes, and 8 pin has 4 modes
http://waterheatertimer.org/pdf/OMRON_H3CR-multi-function-analog-sell-sheet.pdf
How many pins do you have?
What exactly are you controlling with the timer?
And what function are you using?
Sep 04, 2012 | Omron H3CA-A Multifunction Digital Timer
Sony cd player, CDX-3100 wiring diagram
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
This is looking at the connector with the wires towards you.
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
16 Yellow Battery
Feb 24, 2010 | Sony Car Audio & Video
Rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Sep 30, 2008 | Digi (76000200)
Omron Healthcare Omron H3cr-a-ac100-240v Timer 0.05s-600h Dpdt 5a250vac Logo
173 people viewed this question
Top Omron Healthcare Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Omron Healthcare Hardware and Accessory Expert? Answer questions, earn points and help others
