Leaking from bottom center - Washing Machines
  • Washing Mach... Master
  • 2,696 Answers
If it's leaking from the middle of the tub where the tranny shaft is you have bad tub seals,it would cost to much to repair and if you want to fix it you need a spanning tool to get at the seal.
Posted on Apr 09, 2011
    Problem Solver:
  • 19 Answers
Sounds like ur seal is bad replace it u should be good to goooo
Posted on Apr 08, 2011
DISHWASHER LEAKING FROM CENTER OF BOTTOM OF DOOR
It's possible the bottom spray arm isn't rotating, and all thenwarermis being sprayed directly at the center of your door. Check this first. end, check the spray arm isn't damaged, as this can alter the spray pattern.
Jan 12, 2018 | Kenmore Dishwashers
The washer is leaking from the bottom
Your center seal is going bad or you have a bad hose, leaking water pump, or a cracked tub but GE is notorious for there center tub seals to going bad I would recommend a qualified service technician come look at it to rule out which one it is if your centers tub seal is bad I would buy a new washer but sorry for the troubles.
Jan 22, 2011 | GE WBSE2090A Top Load Washer
I have water leaking from the middle bottom of washer, not leaking from hoses or water outlet
sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
Nov 15, 2010 | Maytag SAV5710 Top Load Washer
The dishwasher is leaking at the bottom center of the door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Apr 20, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Leak under door
Leaking Dishwasher
heatman101
s7657usut
Mar 07, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
Oil coming from gearcase,looks like it is weeping out of the bottom center plug. modle la9500xt
it is most likely leaking from the seal on the side and leaking down to the bottom. 2ad94fc.jpg
Aug 01, 2008 | Whirlpool Washing Machines
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Washing Machines Logo
Top Washing Machines Experts
