Question about Jensen VM9020TS Car DVD Player
Hi i bought a jensen JDVD-3000 MKII but i cant see the power amp remote wire, how do i connecvt it to my amp?
5 Suggested Answers
Vulfen
  • 5 Answers
SOURCE: Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Posted on Jul 15, 2007
  • 140 Answers
SOURCE: power on
you must use same cable used to power sound unit.
also check if the sound may have a remote connector.
Posted on Dec 05, 2007
SOURCE: Hi if got the jensen
Connect the green (parking brake) wire on the player to the black (earth)wire on the player.
Posted on Feb 28, 2011
SOURCE: need the Bluetooth pair code
Hi Charles
The factory code is 0000. If a previous user has changed this, you are out of luck.
Mark
Posted on Apr 05, 2011
My jensen jdvd-7700 keeps on loading nothing happens
contact jensen sounds like a faulty dvd player if still under warranty they should fix it for free
Feb 25, 2013 | Jensen Car Audio & Video
I have a jensen JDVD-4301 4in1 car audio system and if i put a dvd into the radio it has no picture but do have sound and it gives me a "warning please stop watch video player" message on the...
there's a green wire thats s'posd 2 go 2 the handbrake switch. Ground this wire 2 any ground of the unit and voala. Its a safety feature of the unit.
Jan 13, 2011 | Jensen Car Audio & Video
Need the Bluetooth pair code jdvd-dd7 (jensen car radio)
Hi Charles
Mark
Dec 25, 2010 | Jensen GPS
I connect my alpine cva 1003 to valor dv-169T dvd player. sounds come out but the screen is not getting connected to dvd player. i connect red, white and yellow wires.
if evrything is ok with the dvd (make sure the dvd is working fine), you need to hook up the yellow/ blue wires and yellow / black wires one for parking breack and the other for the breack chek the diagram on top of the alpine radio .
Jun 15, 2010 | Alpine CVA-1003 Car Video Player
Have Power going to the amp. Amp does not turn on. Do i need a remote? Bought vehicle with amp in it. Lxa 600 Power light does not turn on.
ok remote does not mean the clicker to ur tv its the wire that leads from the back of ur deck to the amp itself to tell the amp when its cool to turn on n off either blue or blue n white is the remote wire on the back of ur sterio run it to remote term. on amp n c what happens
May 14, 2010 | Jensen LXA400 Car Audio Amplifier
Power on
Dec 04, 2007 | Jensen XA2150 Car Audio Amplifier
Pleae help me with my radio
Hi Ant81,
You should only have the Blue wire from the Dual connected the REmote terminal on the Jensen Amp. The Audio cables are the only other wires that connect from the Dual to the Jensen Amp.
Nov 25, 2007 | Dual XDM6830 CD Player
Jensen XA4100
try using power directly from main to the remote terminal to see if headunit has a problem or the amp.please disconnect remote from head first.
Aug 18, 2007 | Jensen XA4100 Car Audio Amplifier
Jensen VM9020TS Car DVD Player Logo
139 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
