Question about Refrigerators
My fridge will only work on 220 volts but not on 12v or gas anymore. the fridge worked perfectly then the gas stopped working one day, i discovered that the gas pipped was blocked, after unblocking it the gas flame was very large and we had to tune it so the flame was lower by turning the gas nearly of, it was after this that the fridge stopped working on gas and 12volt. I am not sure if the 12volt ever worked properly as we mainly used gas and only turned on the 12volt when we moved but we never traveled for longger than an hour. the 12volt draws power as we have a volt meter built in the camper and it shows a power drain when its turned on. thank you for all your thoughts. Regards Nic
    Guru:
  • 683 Answers
Your refrigerator has a freon that we call R-717 which is amonia. You have to heat the amonia to have refrigeration. using the 12 volt side will cause power drain on batteries. If you had to close the gas valve most of the way down this is telling me that he gas pressure regulator went bad. The 220 volt heater is still working that is why this is working. change the regulator and you should go back to gas for operation. If the helps give me a rating please. thank you.
Posted on Apr 08, 2011
Testimonial: "Thank you for your reply. The gas is now working at the correct level but the fridge still will not cool on 12v or gas only still 220volt. Regards Nic"
  • 1 more comment
  • Walter Kunesky
    Walter Kunesky Apr 10, 2011
    did you try bleeding the gas line at the appliance?
  • nicseckold Apr 11, 2011
    yep i shore did, the gas is working perfect, the system heats up but does not cool on gas, it still only works on 220volts.
    thank for ur help Water.
  • Walter Kunesky
    Walter Kunesky Apr 11, 2011
    when the gas is on and lit do you feel heat comeing from exhaust outside?
We have a 1993 Wilderness RV with a Dometic refrigerator, brain box being of Dinosaur brand (which is ok - reaching 120 volts) Our question is on the front freezer door of the fridge is a strip plate...
Hi
Most of these mobile refrigerators can run on gas, 120v or 12v, your gas option is obviously OK, there should be electrical connections on the back of the unit which identify which cable are 12v and 120v.
Again most but not all units were multi option.
You will need to connect these points to the supply. To run this on mains 120v you will need to switch off the gas and 12v, similarly for 12v, no gas or 120v, and for gas no12v or 120v.
If you get the fridge to run on 12v remember that if it is on overnight it can reduce the battery charge.
The best options for these is gas or 120v when you have a mains hook up
Hope this helps
Gordon
Apr 18, 2011 | Dometic Refrigerators
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Motorhome fridge not working on 12 volt
if you are using an amonia cherged fridge, the amonia in your system normally cristallises after not yousing you fridge forf a long period of time. try to put the fride upside down for a few hours or a day and the turn it upright again. re connect your 12v to teh fridge and it will certainly work again.
Sep 07, 2009 | Dometic RM2652 Refrigerator
Thetford Fridge N112
There is a very likely possibility that the resistance heater for the 12 Volt side of the operation is open. This heater can be checked for continuity using an OHM meter from the terminals for the 12 volt .
Jun 02, 2008 | Thetford Refrigerators
Hi i have a 3 way electrolux fridge. it cools perfectly well on the electric mains, I've not tried the 12v, but it fails to cool on the gas. The gas ignites but fails to cool the system.
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
May 28, 2008 | Electrolux Refrigerators
Refrigerators Logo
409 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
