Question about Haier Washing Machines
My haier hw-c1270 is not draining it is stopping the cycle at spin
    President:
  • 1,654 Answers
These front load washers have pump filters and when something gets in them the plug and stop the machine from draining.On this machine I believe at the bottom right front of the machine there is a 3 inch plastic cover , remove this cover to revial a 2 inch circular scew/disc . this is the filter unit , I removed this screw / filter (make sure you are outside or a place with good drainage as this will drain all the liquid from the washing machine) clean it out and run water through the detergent compartment to make sure it is clear. This should get it but if not then check the door for the lid switch.There is a magnet in the lid on the side that needs to connect to the sensor within the machine, it could be that your magnet has come away or dislodged, worst case is to puchase a strong enough magnet to glue on or to replace the lid
Posted on Apr 08, 2011
  • Prem Mulberry Apr 13, 2011
    A good source for Haier washer service manuals is here: http://steprightupmanuals.com/washing-ma...
  • 822 Answers
Pump might be blocked............clear pump........job done.....
cheers
Haier washer model xqbm22-c, fills with water and won't wash or spin, just hums through cycle and will drain. What are possible problems?
bad water pressure switch, bad door switch? bad motor coupler and or belt. the water pressure switch does not control the spin though? so I suspect door switch or coupler
Mar 07, 2015 | Haier Washing Machines
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
Haier hw-c1460tveme-u error 7 smelt like burning rubber the machine was on spin cycle when it stopped with the error the 7 way plug has been removed then replaced the machine will fill and drain but...
hello check the belt at the back it might have come off or snaped got trapped and started to burn. if ok then the motor could have burn't out or circuit board burn hope it helps
regards
shaun
Apr 04, 2011 | Washing Machines
Front load whirlpool washer wont drain. (ghw9150pw0) I cleaned the trap, ran the spin and drain cycle. It gave me the suds message, but then the load drained fine. I then ran an empty cycle hoping to...
I don't know if this will help you, but we have a Haier HNS1460TVE and this is apparently made by Whirlpool ... we have a similar problem in that if the load is not full it will not spin, it stops at 9 minutes and just gets stuck !!!
We have found that emptying the machine & turning it off and on, with the door shut, resets the machine ... hope that helps you !!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Haier HLP20E won't drain the water out, i think it's the pump...what say you???
CHECK THE LID SWITCH, THAT CONTROLS THE POWER TO THE MACHINE DURING THE SPIN/DRAIN CYCLE, BROKEN LID SWITCH, NO POWER TO GO INTO SPIN AN IT WON'T DRAIN
HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | Haier HLP20E Top Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Washing Machines Logo
152 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
