Question about Sony DVP-SR200P DVD Player
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could you please help me correct this problem. Thankyou very much Vicki Edwardes
  • Sony Master
  • 508 Answers
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Posted on Apr 08, 2011
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
Why is there no color
If using component video out please make sure that all cables are firmly and securely connected to the player and the TV.
-Component = Green/Blue/Red cables or jacks.
If using the video out please make sure that the TV color settings are not set to grey or black and white.
If everything is connected properly I would recommend to connect the player to another TV to see if the same issue will occur. Also check the color settings on the DVD player under picture mode.
Ref: http://www.docs.sony.com/release/DVPSR200P_US_ES.pdf
Dec 18, 2012 | Sony DVP-SR200P DVD Player
I am only getting black and white pictures when using the sony dvd -DVP-SR200D when hooked-up to tha TV
Change your tv colour System in to Auto mode.It will adjust in menu.Mostly DVD recorded on NTSC 3.58 colour system.After adjust on auto mode Colour will come.
Oct 30, 2010 | Sony DVP-SR200P DVD Player
I am hooking a dvd player to our new flat screen....I hear sound but no picture
at the side of the flat screen there is tv in so check the cord and make sure it goes directly to tv in ok.
May 23, 2010 | Sony DVP-SR200P DVD Player
I need to unlock the DVP-SR200P to play all regions.
Tell that to my DVP-SR200P ¬_¬
I just bought it, It's regoin 4 and it doesn't play other ones.... I just found out!!!!!
MONIQ
Oct 09, 2009 | Sony DVP-SR200P DVD Player
In Need of DVD code for Sony DVP-SR200P
Unfortunately the only region code your Sony will play is the one that is printed on the bottom of the unit.
Jul 15, 2009 | Sony DVP-SR200P DVD Player
I just purchased a Sony DVD player...DVP-SR200P. Plugged it in and have no color...movies play in black and white only.
Hello cherylsacket,
Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 10, 2009 | Sony DVP-NS700P DVD Player
Sony DVP-SR200P DVD Player Logo
353 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
