Question about Cycling
How 2 fit chain round 6 speed rear wheel - Cycling
    Brigadier General:
  • 8,546 Answers
My YTH2648TDRF has only one rear wheel that engages the mower, shouldn't both rear wheels drive?
The rear drive uses a differential to drive the rear wheels, just like a car, the differential drives the wheel with least resistance, to enable the wheels to revolve at different speeds when going round corners; so it's quite normal for only one wheel to be driven. If your mower is having difficulty with slopes (do you call them grades?) I suggest you fit a new drive belt, a slipping belt is the most common cause of low power. Hope this helps.
Jan 12, 2016 | Husqvarna Garden
When riding the peddles slip,it appears that the chain is engaged and that the axle is slipping and make s the peddles spin, not engaged
If this is a coaster brake bike (single speed, no hand brakes) then the problem might be inside the rear wheel hub. If that is the case then you can only fix it by completely dis-assembling the rear wheel hub - or it might be simply that the chain is slipping, which would not happen unless the chain is too loose which would be indicated by the bottom of the chain hanging down too low. However, if this is a multi-speed bike, then it could be that the chain and rear-wheel cogs are worn - which can be fixed by replacing the freewheel and the chain - however, it takes a lot of use or rust and dirt before that level of wear happens.
Aug 07, 2012 | Trek Mystic 16
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Feb 24, 2012 | Cycling
How to remove back tire to replace tire
Not much info to go on so I am going to make some assumptions. That is that you have hand brakes and multiple speeds so that you have several sprockets on the rear.
1. Take a pic or draw one on how the chain is run so that you can put it back the same way.
2. You will need to loosen the cable that operates the rear brakes to allow the jaws of the brakes to open all the way so that the tire will fit thru them.
3. Loosen the nuts on both ends of the rear axle.
4. Begin slipping the axle out of the slots in the frame and as you do that you will have to remove the chain from the sprockets. While doing that notice that the chain is on the inside of the frame so that when you are ready to replace the rear wheel, you will need to put the chain on the sprocket BEFORE you position the wheel in the frame and the axle in the slots on each side.
If you have another bike similar or a digital camera, the other bike or a good photo will be very helpful when putting the chain back on and the wheel in place.
Tools needed- appropriate wrenches- a small and medium crescent wrench would be ideal as you may have metric size nuts and not have the correct open wrenches.
Once the wheel is removed you will need to let ALL of the air from the tube to give the maximum flexibility to work with the tire. Use a medium blade screw driver to pry the tire over the edge of the rim. Once you have about 6 inches over the edge of the rim you can do the rest by hand. Now that the tire is half off do the same process for the other side of the tire.
Jun 29, 2011 | Cycling
Crackling sound in the chains while driving and something sound like a tambourine somewhere in the rear brake.tnx
It sounds like the bike needs a new chain and probably new front and rear sprockets as well. The sprocket teeth should have a rounded blunt end. Do the replacement of chain and sprockets and then see if the tambourine has gone away. If not, I would dissasemble the rear wheel and brake for inspection. Loose or broken parts, wheel bearings gone bad or brake assembly problems may be present. Please rate my answer. tombones49_195.gif
Jun 23, 2011 | kawasaki ZX-12R Motorcycles
Took chain off to remove wheel and am unable to get chain back on correctly. 2001 Magna oasis 26" 7 digit shifting speed. Unablew to locate manual...can you help?
Put the chain to the inside of the front cog wheel, beside the pedals, first but not onto it, so you have plenty of room for pulling the chain to the rear. Fit the wheel back into place and before tightening it pull down the spring loaded arm, with the small cog wheel beside the back wheel. This takes the tension off the chain and allows you to put it into place on the back wheel. Tighten up the wheel. When it's tightened fit the chain onto the top of the front cog wheel. Lift the back wheel off the ground and turn the pedals forward. The chain will click onto the front cog wheel when you have turned the pedals one complete turn.
If you need to see a picture of how it should look at the back you can see one at http://orangecounty.craigslist.org/bik/2409696114.html
May 29, 2011 | Cycling
Bought a 03honda cbr 600rr, front sproket had been changed out and rear tire moved back. chain is loose 2"+ in slack but i can not move tire back any further in swing arms. can I move rear tire up and...
hi, prob good idea with this will be to slacken off the wheel push the wheel forward and fit a chain the correct length for the set up you have, count the links in the chain you have on the bike and get one 2 links shorter, mark a link on the chain with paint or sim turn the wheel and count the link plates, ie 1 plate is 2 links, so start on the 1 next to the marked 1 turning the wheel counting the plates 2 4 6 8 10 etc and end on the marked 1 this will give you the number of links already on the bike
Jan 15, 2011 | 2003 Honda CBR 600 RR
Slapping noise after chain adjust
hi there,,1,5, to two inches is correct,, is that all the way round by the way, sometimes u can have a tight spot,,it seems correct sometimes wen adjusted in one position,, but spin the rear wheel round it will either slacken quite a bit,, or go very tight,with no play in it,,,your cush drive rubbers behind the rear sprocket housing on the wheel,, may have a bit of wear in it,, or the chain haz a stiff link in the line,, and needs more oiling,, if the chain is dry ,and right now in salty conditions it will be, then that will cause chain slap,,,
Jan 21, 2009 | 1987 Honda CBX 250
Toyota caldina 1998 GT
must put chains (if you really need them) on all 4 wheels of your all wheel drive car to prevent a speed mis-match between front and rear...a mis-match can destroy the gearboxes over prolonged use. use chains that have many cross links to lessen the effect of any speed mis-match
Jul 03, 2008 | 1998 Toyota Corolla
Cycling Logo
14 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
