Hi, I have a 2gb usb flash disk. The problem is, everytime I try to format it a dialogue box displays "Windows cannot complete the format." All files are deleted so I eject my flash disk but when I insert it back to the unit, all the file I deleted a while ago, was there again. Is it infected or is there a software I could download from the net, like a formatter or something? I hope you could help me solve this problem.
  • 368 Answers
Glad to HELP YOU!
You need a software to get installed on your machine so to make that annoying message to disappear. The application is called UNLOCKER and you can have it from HERE [it's FREE...!].
After installing this application right click on the drive that you want to format and click on UNLOCKER.
The moment UNLOCKER will open select UNLOCK ALL.
Now you have to be able to format your flash drive without any problem.
My best wishes for YOU!
Posted on Apr 08, 2011
Tip
HOW TO FORMAT YOUR USB FLASH DISK
Start your computer and plug in the flash drive in the USB port.<br /><br /><br />Click on "My Computer." Click on "Manage" in the "Explorer" window of "My Computer."<br /><br /><br />Open the "Device Manager" and locate your USBDrive installed under the "Disk Drives" tab. <br /><br />Right click on "Removable Disk Drive" and click on "Properties" from the menu.<br /><br /><br />Click on the "Policies" tab and choose "Optimize for Performance" from the options. Click "OK" <br /><br />and continue.<br /><br /><br />Click on "My Computer" and choose the format on the flash drive.<br /><br /><br />Choose "NTFS" or "FAT32" depending on the type you want from the dropdown menu box.<br /><br /><br />Click "OK" to complete the format.
on Jan 30, 2011 | Computers & Internet
I just bought 2gb SanDisk Memory Card, a few days ago it requires to be formetted and I dont know why. When I intend it to format at my PC it just says "Windows can't format E:/". What should...
try using linux
then also try using your phone or whatever the disk was to be used if not then g to control panel and look for the administrative tool click it, go to computer management and try format it from there. If all this can't work then, return the product to the dealer
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
Whenever formatting my USB Data Traveler (Kingston 2GB DT 172GB ) (CN 051008 5V), my window always show me " Windows was unable to complete the format. " and whenever i put it in my USB Port, it...
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive if you still want or need to format
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps"
Jul 15, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am unable to save anything to my flashdrive.I am unable to format my 2GB USB Flash drive. I have tried formatting in through "My Computer" I've done it through the "Command...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
hope this helps
Jun 21, 2011 | Dane-Elec DaneElec 2GB USB External Blue...
Whenever i try to open my 2GB flash disk the instructions i get is that it is not formated. when i order for formating, it tells me that windows is unable to complete. What can i do?
try this, in start type cmd and you will given to dos mode the type format + drive leeter which assign in wor flash ex. e:/u and put the parameter u
May 30, 2011 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Hi friends, Actually I've a 2GB Micro SD it displays "Writing Protected" error while I trying to format it in windows environment with Third Formatting tool and It displays "msdc write...
Check the little white switch on the side of the memory card. That is the write protection switch. Turn it to the off position and try formatting again.
Apr 22, 2011 | SanDisk 2GB microSD Memory Card
Sandisk Cruzer Micro 2GB Usb Flash Drive. Windows was unable to complete format!
Try this:
STEP 1 - Optimize the flash drive for performance
1. Plug in the device to the PC.
2. Double-click My Computer.
3. Right-click on the flash drive, then select Properties.
4. Click the Hardware tab.
5. Select the SanDisk Cruzer USB Device disk drive, then click Properties.
6. Click the Policies tab.
7. Select Optimize for performance, then click OK.
STEP 2 - Format the flash drive
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
