Question about Boston Acoustics AVR7120
My BA AVR 7120 seems to work fine in stereo mode but when I switch to surround (i.e. Matrix mode) the sound cuts out from the speakers and sometimes the display disappears and the receiver goes into standby mode after which I have to turn off the power and turn it back on before the receiver will power up and play sound again. If I put it into stereo mode when the receiver turns back on, the receiver works fine. What's the problem and how can I fix it?
  • Jason Fishburn Apr 11, 2011
    I don't think impedance is a problem because these are the same speakers I've used with the receiver since I purchased it 5+ years ago. I have Infinity's all the way around (Beta 50's for Front Speakers, TSS-1100 Center Channel, and RS-5 for Rear Speakers). Wiring should also not be an issue as I am using Monster Cable that is at least 16 gauge, but I'm pretty sure it's 14ga.
    And yes, I realize that the surround speakers won't work in stereo mode but I brought that up because the overload protection does not seem to be kicking in while in Stereo mode and I've been running it that way for the last few days without any problems so now I suspect that there may be a problem either with the surround hardware, the wiring to the surround speakers, or a problem with one of the surround speakers that's causing a surge back to the receiver so do you have any recommendations on how I might narrow this down? I thought about disconnecting one surround speaker at a time to see which speaker (or speaker wire run) may be causing the problem. What would you recommend to try to troubleshoot this problem?
    Thanks in advance!
    Genius:
  • 1,622 Answers
Hi, Sounds like the overload protection is cutting in. What impedance speakers do you have connected to the A and B speaker connections? If the impedance is too low the receiver will try to output too much current and the system will overload.
Also what volumes do you listen at? Is the receiver hot to touch before it shuts down? Check all your speaker wire connections and make sure no wires are touching other wires or speaker terminals at the receiver end and speaker end. What size speaker wire are you using?
It might be an issue but I have heard of problems like this when they used very thin wire. How long are the wire runs? Do you have any 14ga. wire you could try? 16ga wire should be the min. you should use on very short runs (unless you are using HTIB speakers).
I don't think the wire is an issue but I have heard of problems like this when they used very thin wire. How long are the wire runs? Do you have any 14ga. wire you could try? 16ga wire should be the min. you should use on very short runs (unless you are using HTIB speakers).
No Surround Speaker Sound
If your surround mode setting is set to "Stereo," your surround speakers will not function. To remedy this, just change the surround mode. Push the "Surround Parameter" button either on your receiver unit or the remote control to access the surround mode settings. Push the "Select/Enter" button on your remote control to cycle through the surround modes: "Direct," "Stereo," "Dolby Pro Logic," "Mono Movie," "Rock Arena," "Virtual Surround," "Matrix" and "Video Game." Select any option except for "Stereo."
Makes sure that none of the speaker wires are shorted across the terminals at the speakers or at the amp. Just one stray strand can cause an amp to go into protection.
Posted on Apr 08, 2011
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
No sound
check speaker conections. disconnect all the speaker wires and use one speaker that you know that works and connect it to each channel one at a time. most surround sound stereos will not go into surround mode unless all the speakers are connected so make sure stereo is in 2 channel mode to start testing. check all fuses sometimes amp fuse is seperate from power circuit and denon uses relays in 99% of thier units.
Dec 23, 2010 | Denon AVR-2802
Harman Kardon AVR 500 Only works in NON-Surff mode ?
This is a good indication that the surround processing section has a problem. This can be anything from a supply voltage being missing to a defective processing IC. Without testing inside the unit, it wil be difficult to determine. With surround procesing turned off, the entire section is bypassed. This is why standard stereo mode sounds OK. The static sound is digital noise and can be poor processing or a bad D/A converter IC.
Hope this helps,
Dan
Feb 26, 2010 | Harman Kardon AVR 500 Receiver
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
No surround on Denon AVR-485
Hi you must put the amp into prolgic mode this is fed by a stereo siganal the rears will sound vague and hollow that's all you will get this willnot work with 5.1 or 7.1 good luck
Feb 22, 2009 | Denon AVR-485 Receiver
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
Rear and Centre speakers not working
The system comes with l remote which provides controls for "Power", "Master Volume", "Bass (Subwoofer) Volume" and "Matrix Mode" . Matrix mode allows you to spread stereo sound to all speakers where your sound card may not have the ability to do so.
I find that the "Stereo Surround" setting works best as opposed to the recommended "CMSS" setting
Oct 22, 2008 | Logitech X-540 Multimedia Surround Sound...
I have an Harman kardon receiver (avr 310) it only plays in left and rigth speaker with surround off . I try everything to make it work in other but it can't .
Surround only works from a surround source such as Pro Logic.
If you are useing a regular stereo source with surround off, the sound will come only from L/R speakers (and sub woofer if used)
Apr 22, 2008 | Audio Players & Recorders
Boston Acoustics AVR7120 Logo
141 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
