Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
    President:
  • 1,654 Answers
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Posted on Apr 08, 2011
      Producer:
      Uploaded 30 video answers.
    • 117 Answers
    Maybe worth a look at this video
    Posted on Apr 25, 2011
    How to get rid of black mould?
    Do a long hot wash, add bleach. Stop using fabric softener. If the rubber boot on the door (Front loaders) has been stained with black mould, you wont get the stains out. It will need a new gasket.
    Mar 20, 2017 | Washing Machines
    How do i clean Bosch WAE20261AU front loader washing machine
    The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
    Apr 27, 2013 | Washing Machines
    I have a 18month Electrolux 8kg front loader which has mould on the bottom part of the rubber seal. I have always kept the door open after every wash but the mould has set in. I have tried wiping it with...
    You will find that wiping it dry, then painting it with thick household bleach and leaving it overnight will have an excellent effect on the staining. The rubber will tolerate the bleach without any problem. If one night doesn't quite cut through the mould, treat again the following night.
    Just remember to wash the bleach away thoroughly, so that it doesn't affect any garments in the next wash!
    Jul 29, 2011 | Washing Machines
    How do I clean the mould in the rubber door seal of a Bosch front loader.
    This video will show you how to change a door seal on this Bosch front loader washing machine
    we have all bosch repairs in our channel
    Apr 01, 2011 | Bosch Washing Machines
    Mould inside rubber seal
    Bosch Axxis WFL 2060 Front Load Washer mould on door
    gasket.
    This video will show you how to change a door seal on this Bosch front loader washing machine.
    we have all bosch repairs in our channel.
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 24, 2011 | Bosch Axxis WFL 2060 Front Load Washer
    Black mould
    this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
    May 13, 2010 | Zanussi ZWF1440 Front Load Washer
    Front loader mold around rubber seal
    Spray with bathroom mould remover and leave for one hour. Wipe and repeat as necessary.
    Mar 23, 2010 | Washing Machines
    My 2 year lold front load GE washing machine has developed a lot of mould in the rubber gasket on the front of the machine. I have tried to bleach it but the mould remains. It causes the cloths to have...
    on my lg, there are two small drain holes in the folds of the gasket that got plugged up with lint and stuff, unplug them if you have them. also i leave the door open after wash to let it dry out
    Jul 24, 2009 | GE WBVH6240F Front Load Washer
    Black mold growing on gray rubber boot inside door.
    Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
    Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
    942 people viewed this question
    Top Ariston Technologies Washing Machines Experts
    Darren Moxam
    Darren Moxam
    Gerry Harvey
    Gerry Harvey
    Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
