Question about KiasWorld Chat
I need to know do Carens (2005) diesels have TIMING CHAIN OR CAMBELT
    New Friend:
  • 60 Answers
Timing Chain.
Register to http://www.kiatechinfo.com/.
Much the same web site as the dealers have. As this site is for USA there is not much about diesel but everything else is there
Posted on Jun 09, 2011
Can someone tell me if the 2005 Mazda 6 2.0 diesel 136ps has a cambelt or chain? If it is a belt when should I replace it. I'm on 116000 km's.
Filipe, Gates is a timing belt manufacturer and they recommend changing belt every 100,000 KM. This is what is known as a interference fit engine, If the timing belt were to break, it could cause extensive damage to valve train. Through some searching, recommended Timing Belt change interval is 60/75000 miles or every 72 months. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.mytimingbelt.com/Results.aspx?ModelId=52
Mazda 6 2 0D Cambelt Change
Timing Belt Replacement and Technical Info
http://www.deserttruckservice.com/pdf%20folder/gates_timing.belt.replacement.chart.pdf
May 18, 2016 | Mazda Cars & Trucks
I just bought a Kia Carens Diesel Auto 2003 model LX. Can you tell me if this has a cam belt or a chain? If a cam belt, what are the recommended miles to get a new belt fitted?
check the timing cover and if it is plastic it will be a belt operation. If it is aluminium and sealed off then it will be a chain. Belts are recommended for a change at 60.000 miles (100.000 klms) but this depends on driving conditions ( constant high rpms) and oil on the belts ( oil reduces the servicability of a rubber belt considerably)
Nov 12, 2014 | Kia Carens Cars & Trucks
Does a vauxhall corsa 1.2 diesel have a cambelt
i work on them and i cannot remember what a good mechanic i am but i dont think they do they have a timing chain i think .when next customer brings one in i will have to have a good look
Aug 22, 2011 | 2005 Peugeot 405
Does the suzuki grand vitars 2lt diesel have a cambelt
not so sure what a cambelt is, but it would have a timing belt.
Best regards
Ck
Mar 06, 2011 | 2005 Suzuki Grand Vitara
Does my golf 1.6 fsi have a cambelt or chain 2005 model
your car has a timing belt.I would recomend also changeing the water pump if you are going to change the timing belt since the water pump is ran by the timing belt.I hope this ws helpful.
Feb 07, 2010 | 2001 Volkswagen Golf
Cambelt or chain
Your 2005 VW Golf has a timing belt and not a chain.
Most importantly, your VW has what's called an interference engine.
If th eblt breaks, it will allow the valve to collide with the pistons and you will have major damage.
Be very careful to replace the belt on or before the manufacturer's recommended replacement interval.
VW originally recommended 60k miles or 5 years but that in 2004 or 2005 they changed that to 40k miles or 3 years after seeing belts (and therefore pistons and valves) go pop after about 45k.
I need a diagram of an ford focus timing chain and cambelt for x reg 2000 i am tranferring a timing chain and a timing belt and diesel pump from one engine to another. im not sure how to get the engine to...
TDC has marks on the pulleys and engine block to line up, best bet is to get a haynes manual to show you exactly where. Too complacated to explain where they are on this
Sep 03, 2009 | 2000 Ford Focus
Camshaft sensor
Do you know if the engine timing is correct? If you get the timing a tooth out you very similar issues, has the cambelt been replaced recently - or is it over due??
Another posibility is the cam chain adjuster. This is oil pressure fed and I think controled by a solnoid, it applies a force between the chain that drives the inlet camshaft from the cambelt driven exhaust camshaft. (Making any sense? Let me know if you want me to simplify) This operating correctly advances and retards the valve timing, when faulty it can make it incorrect. Non start is a fault caused, but more often they become very noisey.
The cam chain adjuster is fed oil when the car is started, you can breifly here it before it has reached operating pressure on normal start up, sounds like a diesel knock for a second, then goes, this is normal. If it continues, its more than likely faulty.
Let me know if you want any more info. If the sensor and wiring is good you'll probably have a timing issue.
Mar 24, 2009 | 2005 Audi A3
Facebook Apps Logo
43 people viewed this question
Top KiasWorld Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a KiasWorld Facebook App Expert? Answer questions, earn points and help others
