Question about Cell Phones
I dropped my X6 into the toilet (post flush!) and now it won't turn on at all. i realise it is fried but is there a way to extract the information - pics, etc that I have created since my last download?
  • Cell Phones Master
  • 32,281 Answers
If you photos was stored on a mini SD memory card, then remove this mini SD card and insert it into an USB card reader. Connect this card reader into a working computer's USB port. If the mini SD card id not damaged the this computer will detect it as an external storage device and if you can open the various folders then you can copy and backup your photos.
Posted on Apr 08, 2011
Loose water pressure after flushing toilet
That is normal. If you want less pressure fall turn the water supply line half off.
Oct 21, 2017 | Drops Home
Do you turn the screw to the left or right on a american standard toilet to adjust the water level in the toilet tank
Usually to the right will drop the float, deceasring the water level, left will increase the water level.
Aug 25, 2014 | Cadet Manufacturing American Standard...
Kohler flush problems
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
Aug 21, 2014 | Home
Toilet flushes but does not have the power to flush down waist
Aug 14, 2014 | Home
Toilet wont flush
Jul 27, 2014 | Home
Motorhome toilet won,t flush
Make sure the water supply to the toilet and the pump are working properly, make sure waste tank is not full, if it still won't flush check the flushing mechanism on the toilet.
Mar 01, 2014 | Sport & Outdoor - Others
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
