I have a newcomputer and do not know how to install and use the SanDisk. I have it plugged into the port but don't know if it is installed or not and if it is, how do I go about saving files to it.
    Guru:
  • 811 Answers
The easiest way to know if this device is installed two ways one there will be a small icon on the lower right bottom of the desktop tray it does vary as to the icon shape but if you scroll through them you will see your Scandisk mentioned there. This is also used for removing the disk do not just pull the disk out without closing it this way first. Also you can left click on My Computer this will bring you into a separate window which displays your hard drive C or other drives if you have them or devices that are installed on your computer it will be located in my computerr. You should see Scandisk there. If not then it did not pick it up most likely this will not be the case it should be there.
Now in order to send files and pull files just use it as another drive if the Scandisk drive is showing it as a letter E: then when you are going to save things to it you can either right click and send files to Scandisk E: or you can copy and past or move them to that drive by dragging files. Or when you get to a downloaded file and you want to save it to your Scandisk E: drive just look for the Scandisk and its assigned letter it just becomes another external drive that is all it is nothing more. Just like C: or D: but it is an external one you placed in the USB port.
Remember very important that you close it down properly or you can loose any saved data in a nano second if you do not close it properly when you are ready to remove it from the USB port. I do hope that this explained it further for you. Thanks for using FixYa! do not forget to place a vote for me if you will! John
Posted on Apr 08, 2011
    Scholar:
  • 91 Answers
Sandisk USB Thumb Drive or memory card
They are plug and play so just plugging it in makes it work
You dont need any additional software
Go To "My Computer"
You should see "Removable Disk or Drive"
Just double click on it to open the drive
Then copy and paste or drag your files onto it
Hope this helps, please rate!
I have a really old computer and I put my flash drive into the where it is supposed to go, but nothing came up. What am I supposed to do?
Some Flash Drives don't come with an "autorun" installed in it, if you have a Windows 7 Operative System, it might be installing the driver for it. If it's already installed, go to your computer menu and check if the drive shows up there (In the "removable drives/devices" area).If it doesn't show up, try plugin it in another USB port, your port might be the on not working.
May 26, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How do i transfer songs to my player???i dont have the drivers installed....
If you have the installation CD use that. You could go to SanDisk web site under downloads or support and download from internet. Final it might be "plug & play". Which means plug the player into a usb port and it will install itself.
Aug 24, 2010 | SanDisk Sansa m250 MP3 Player
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
I have never installed a flash drive want to now how step by step
And u don`t have to - just pop it into free USB port and of u go - let do MS do the rest. In case of Apple don`t forgot to "eject" first
Dec 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sansa e260 player not recognized by window
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) . download and install Copy and paste click run to install follow instructions make sure your sansa is in msc usb mod in the settings in the sansa
Jun 07, 2009 | SanDisk Sansa e260 MP3 Player
Cant install mp3 player
Go into the menu of the Sansa itself and change the USB mode to MSC mode- the user manual will tell you how to do this. Then try plugging it into the computer again. If it still fails, you may have to install Microsoft's MTP Porting kit, but I would have to know your Operating System before i could tell you for sure. Here is a link to some additional information that may or may not be helpful - from people who have had the same problem:
http://forums.sandisk.com/sansa/board/message?board.id=c200&thread.id=3462
-Tha Mp3 Doctor
Jan 07, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk have installed driver but am lost as to transfer data
First plugin the sandisk to your usb port, and then check from Windows Explorer, does your sandisk cruzer detected? you'll get a new drive letter besides your local drive or
named "removable disk".
If you do see it then just do format (you'll lose the U3), copy, store, overwrite it again and again as you like.
If you still need the U3 application, pls read this:
http://www.u3.com/support/default.aspx#CQ1
read no.1
Dec 26, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer doesn't recognise SanDisk sddr-103 as having any capasity.
Don't know this particular one but it is possible the driver software did not install correctly.
Plug it into the US port and restart your system.
This may force Blindows to 'see' it and install a driver or ask you for one.
Aug 05, 2008 | Computers & Internet
SanDisk port
The port is empty.it dosent come installed with this particular series.
Apr 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Couldn´t connect SanDisk Sansa e250 to Computer
I don't know what to tell you, but since nobody else is helping. Make sure that you've got the mp3 player plugged into a usb port.
Oh, and hopefully you're running XP or Vista. Sandisk requires it.
Dec 19, 2007 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
