Question about HP Pentium 4 (p5663-69001)
HP BEEPS WHEN STARTS UP AND WONT RUN - HP Pentium 4 (p5663-69001)
    Guru:
  • 811 Answers
This is a warning that some piece of hardware is not working. You may want to check fans making sure that they are functioning to keep your devices cooled down. If these stop working you may have burned out the CPU chip. Most likely it is a memory stick or a mouse or keyboard that may not be connected properly make sure that everything is connected and in their right ports. What I do to find this out what it is I isolate devices to see if the beeping with stop or it will start the BIOS. I start with the mouse then keyboard then anything that is plugged in externally I unplug one at a time powering up each time I undo a device if the beeping stops then that is the problem device. You can also go in the computer case and undo the hard drive and one stick of memory one by one. If it continues and you have illuminated just about everything then it may be the system board itself.
More than likely it is a memory chip you know it is not the power supply because it starts up. If you do not want to do this process of illumination most folks do not. I suggest you take it in and let the people who can best fix this do the job. They can determine the issue rather quickly by reading the codes on the BIOS flash page when the computer first starts up try and see what it is saying when it comes on if you get the BIOS at least to flash information for you. The machine will say keyboard not installed or no hard drive found. Also you can go back by removing any devices that you just replaced or added this could also be the cause.
Last ditch effort unplug the computer from the power outlet push in the power button hold for about 2-3 seconds you will see a flash. Now plug the computer back in the power outlet then restart the computer this sets your computer back to default settings and loads devices again. Often times this can resolve problems more than likely with beeping it will be a hardware issue. I hope that this shed some light on the issue for you, thanks for using FixYa! John
Posted on Apr 08, 2011
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
http://www.pcdied.com/intel-magic/xw4600.html
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI card.as fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
fully.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
coin.
http://www.pcdied.com/intel-magic/slots.jpg
page 111 is here, 24/7 !
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/WS_UG_xw4600_STRG_453080-001_screen.pdf
Sep 01, 2017 | HP Computers & Internet
Computer starts to power up, two beeps then nothing and wont come on
severe virous you may need to format and reinstall all softwear.
Sep 18, 2012 | Gateway One Computers & Internet
My compac presario PC SR5510F keeps beeping and wont start up? do you know why that would be
When a PC is turned on and then starts beeping, the beeps are actually a message to help troubleshoot. You should listen to the beeps and learn what the pattern is. With that pattern, you may be able to determine the issue.
HP has published a list of these beep codes that are common to many of their system. That information can be found at this link > HP/Compaq Beep Codes
Feb 03, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
Emachine starts boot process but stalls, no beeps
most likeley if you see something on the screen but it wont boot it is a mem problem, does it load bios, if so it is prob not memory
Nov 17, 2009 | E-Machines eMachines Desktop PC
My hp desktop pc wont startup - when i turn iton there are a number of beeps then the light starts blinking red can anyone help?
You need to try and find troubleshooting codes on their website, but the blinking and beeps is actually a code that will tell you exactly what is wrong with it if you know the codes.
Oct 24, 2009 | HP Compaq dc5000 PC Desktop
Hp pavilion723a when starts emits high pitch beeps and wont boot
These beeps are telling you that there is something wrong with the hardware. It means something has failed and will most likely need replaising. The certain amount of beeps will tell you the exact piece of hardware, count of beeps and phone hp and they should tell you whats wrong with it and if its repairable.
Good Luck
Aug 28, 2009 | HP Computers & Internet
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & th
By warble, do you mean a high pitch non stop noise? If so... I think I went through that bout 2 months ago, it was a easy fix. Ifr it is the same problem
May 29, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Dryer stops midway through cycle and wont restart just beeps
If it was really loaded with int, it may have killed the motor. You could take it apart and thoroughly vacuum it. If that doesn't work, I'm afraid you'll need a motor
Apr 09, 2009 | Kenmore 42822 Front Load Washer
Tower wont stay running
Are there any beeps?
Could be the power supply going, motherboard, memory or CPU.
Check that all of the cards are seated correctly and tight.
Feb 06, 2009 | HP Pavilion a420n PC Desktop
Tried to upgrade my hp from windows 98 to xp now it wont come on. It beeps then the monitor goes to sleep.Can not even run my redtore disc.
At start up of computer start tapping the f-2 key until you open the bios.In the bios change your drive order so that the computer boots first to CD-rom.
Mar 18, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Pentium 4 (p5663-69001) Logo
204 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
