Question about HP Office Equipment & Supplies
My printer does not work - HP Office Equipment & Supplies
  • HP Master
  • 13,433 Answers
Can you be more spesific, it doesn't print from the computer?
is there a error code in the display? lights flashing?
Brand and model also please.
Thanks,
Ekse
Posted on Aug 06, 2008
    Genius:
  • 3,422 Answers
HI,
Can you please describe your problem.Also please let me know the make and model no. of your printer.
  • Priya darshan Aug 06, 2008
    First try upluging the printer while it is on for 70 seconds. The plug
    it back in now check to see if it show the same display. If it does
    then delete the printer and upload a new driver from the HP site
    and install the driver be sure it matches your operating system on the
    computer.
Printer stopped working
Please check it power cable or power board, if power section ok or working.
Then check you printer connection or not.
Check printer cartridge shot or not detect.
Check it printer head, if header not working then not print coming.
Check it your printer driver installed or not, if installed may be some problems then your printer not working. So old driver delete or new driver installed.
If other issue please tell you.
I hope solved your issues.
Thanks,
HP Printer Problems
Jun 18, 2014 | Brother HL-2040 Laser Printer
Working printer will now not be detected windows xp
Do you have the correct XP driver for the Printer? If yes check that the cable that connects the printer to your system is not damaged. If you have another working system near by you can connect the printer to the system and confirm the printer is working. If the printer is still not working, the printer port may be bad either on the system or on the printer. In this case you need a technician to help you confirm which is the faulty one.
Jun 07, 2012 | HP LaserJet 4 plus Printer
My HP Printer no longer works on my laptop. What
you did not provided any useful information, what operating system you use, what printer, what connection (usb, paralel, network) and what laptop.
general advice only can be provided then.
if windows of any flavour, disconnect the printer, uninstall all software pertaining to this printer. use ccleaner and clean your harddrive including registry.
check printer on another computer if it works. if printer works correctly, problem is with your laptop, not with printer.
follow this procedure, install software, connect printer, switch printer on, windows will automaticaly install drivers and printer software
if this do not work, you need to check if port used for printer work with other hardware, ie, usb stick, check cable between printer and relevant port.
Jul 20, 2010 | HP Computers & Internet
Printer stopped working. pc sending job to
hhhmmm... maybe you have installed the drivers many times.. the printer shows more copies in the printer panel... you must delete those printers... because that will cause conflict ....
Feb 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Printer won't resond to command from computer
restart both printer and computer then report back if any changes
Nov 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Printer A920 not working
Make sure the printer is not set to work offline by right clicking the printer under printers in your control panel. If that is not the case make sure that when you are trying to print the printer is setup as the default printer.
Apr 12, 2008 | Dell A920 InkJet Printer
Lexmark 3400
printer screen shows cover open but it is,none buttons will work
Jan 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
21 people viewed this question
Ben Johnson
