Question about Whirlpool ACC108PS Air Conditioner
How to reset air conditioner model s07s618
I need to reset my air conditionet, I don't find the reset button in the front unit in my bedroom
  • Rizwan Noori May 11, 2010
    there use to no reset button in Domestic Air Conditioner Unless having Microprosesor or more control devices on it
    Pls Kindly Specify Exact Problem
  • 143 Answers
SOURCE: AIR CONDITIONER MODEL #AF-S85FX--CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Posted on Jul 25, 2008
  • 113 Answers
SOURCE: air conditioner unit will not come on ,no reset button
some have a reset on the plug
Posted on Apr 27, 2009
SOURCE: Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
SHUNDE HUA AO
ELECTRONICS CO., LTD
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
Posted on Jun 02, 2009
daddyo742001
  • 70 Answers
SOURCE: air conditioner dripping water
Try pouring some bleach in drain.
Posted on Jun 28, 2009
flatech
  • 111 Answers
SOURCE: TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
Posted on Nov 14, 2009
How do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • Jun 10, 2014 | Amana Acd12ke-e Window Air Conditioner
    E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
    highly annoying issue error code E1. After hours
    of fan operation, the error code E1 will appear on the seven segment
    LED temperature display. This error code is intended as a reminder for
    the user to clean the air filter. However, because the procedure
    outlined in the user manual does not clear this error code as
    indicated, and the appliance has a nonvolatile memory that cannot be
    reset by simply unplugging it, the user of the appliance will become
    mightily frustrated, standing in potentially sweltering heat watching
    the appliance repeatedly shut down in the midst of operation with the
    "E1" display flashing.
    Believe it or not, that is what it does: if you unplug it to remove the
    "E1" code from the display, and plug it back in and re-start it, it
    will simply run for anywhere from a few minutes to a few hours, and
    then merrily shut down again with the same flashing "E1" code.
    So you will come home to a hot bedroom, living room, etc. unexpectedly,
    and you will NOT be amused, as I was not.
    Many people at this point, having put the manual under the canary or
    some such, will simply return the unit and never buy another Sharp air
    conditioner. But for the tech-savvy and search-adept, I offer the
    following procedure to clear the nefarious E1 indication, and obtain
    1. Power down the air conditioner using the "power" button on the front
    panel.
    2. Unplug the air conditioner from the wall socket.
    3. Hold the front panel "power" button down and plug the air
    conditioner in. Continue to hold the power button down as the machine
    goes through a brief test sequence (fan & compressor each come on
    briefly, etc). There is a "beep" sound at the end of the test sequence,
    and the machine will be off. At this point, you can release the power
    button.
    4. Unplug the air conditioner.
    5. Plug the air conditioner back in.
    6. Congratulations! You should now be able to operate the air
    conditioner normally for another 720 hours, but only if you followed
    the instructions above EXACTLY.
    _____________________________________________________
    Was this solution helpful? Show your Appreciation by rating it.
    Thanks for using fixya support..You have a wonderful day
    Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
    My Air Conditioner started blowing hot air. Code p2181 came up. I have had problems with my fuse box over my battery. Could this be the problem again?
  • 2
    Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditiner
  • Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4
    Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor response to detecting room tempeture is needs replacement I say I'd loose business but rather clients trust me then go elsewhere recommend me for what you'll pay get a new one if it doesn't work
  • Sep 15, 2013 | Cars & Trucks
    Our penquin dometic air conditioner in the bedroom pours leaks lots of water when the unit is on during rain storms. Water leaks into the ceiling and also out the unit.
    Sounds like base gasket at roof is loose or defective to start with. Try removing ceiling assembly enough to tighten 4 bolts that secure roof unit to inside bracket. Do not compress too much, just snug them all evenly and see if water slows or stops. If not, you will have to remove upper unit (roof) and replace gasket and re-secure but don't tighten to excessive, only compress gasket approx half of original thickness. Also make sure upper unit is aligned properly with opening of roof.
    Sep 23, 2011 | Dometic Rooftop RV Air Conditioner
    We have a portable air conditioner. It keeps
    Follow the steps below....
    panel.
    button.
    Jun 26, 2010 | Heating & Cooling
    How do I reset the e1 on the A/C
    I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book
    but on my unit you have to do the following
    panel.
    button.
    after following this procedure to clear the nefarious E1 indication, you should obtain
    another 720 hours of cooling bliss
    Jul 20, 2009 | Sharp AFR120FX Air Conditioner
    RV Dometic AC Comfort Control Double EE Problem
    I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
    Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
    Whirlpool ACC108PS Air Conditioner Logo
    295 people viewed this question
    Top Whirlpool Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Bill Long
    Tim Whalen
    Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
