Question about Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi...
Chris@crimmen.co.ukHi my Whirlpool gold fridge freezer is working well but has started tripping the electrics in the house each time it is switched on and the motor strarts - can you help please? Chris
    President:
  • 2,468 Answers
Its either the ptc overload on the compressor body or the start winding on the compressor itself,you will need to have a person with a clamp-probe check the starting/running currents and see how large a current this unit draws at start-up and run,then if too high a draw,its probably a bad compressor motor winding
Posted on Apr 08, 2011
Whirlpool gold gi5fsaxvy02 all lights on front panel flashing & went out completely nothing working refrigeator & freezer out compressor not going on shot
bad compressor relay? bad house electrical outlet no power? and hopefully not a bad control board unit, can be chekced out with a multi meter for continiuty, there may also be some sort of fuse or thermostat that shorted in ur fridge, will need a schematic to check it or call ur dealer
Feb 16, 2015 | Whirlpool Refrigerators
My Whirlpool Gold Series Fridge is not cold in Fridge part, but is still working in freezer part. What might the remedy be?
Could be a few things. One could be a bad evaporator fan motor in the freezer section. The fan motor will only come on when the light switch is closed so make sure you hold down the light switch when you check it. Could be a defrost timer or defrost bimetal. You will know because you will have ice buildup on the back wall inside the freezer. Also could be icebuildup in the return air duct. They are located under the drawers in the refrigerator.
Oct 19, 2014 | Whirlpool Refrigerators
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool fridge freezer tripping the electric
PLEASE CALL PENINSULA ENGINEERING & SERVICES
9224699796 , BASED IN MUMBAI 24 HRS SERVICES 100 % JOB SATISFACTORY
Sep 03, 2008 | Freezers
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Mar 21, 2008 | Refrigerators
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
