Question about Video Game Consoles & Games
HELP... I have a big problem with my PS3. My system was okay when I took it apart for cleaning but i completely disassembled it and cleaned the dust. I put it back together and now it wont work! When I turn on the power switch in the back the red light turns on in the front... but when i press the start button, the green light turns on for a second with a beep, then the lights go out immediately ...it turns off! I did not use any thermal paste or compound. Can that be enough to cause me my problem? I might have caused a tiny baby scratch on the mother board also! Can this be it? HELP whats your opinion?
    Scholar:
  • 91 Answers
I fix PS3 Yellow Light of Death.
When you say you completely dissasembled it i guess you mean EVERYTHING?
Well did you make sure you plugged the battery back in? and Made sure all connections were placed back?
If you took off the heatsink and fan from the chips then that is why it switched off!
You should have put new paste on if thats the case!
The PS3 seems it is shutting down to protect itself from overheating and burning the chips!
The baby scratch should be ok unless it has destroyed a copper track?
Goodluck let me know how it goes and please rate!
Posted on Apr 08, 2011
I completely took apart my holmes air purifier to do a deep cleaning to get the fans and evreything dust free. need diagram to put back together. HAP9422 (model)
Hello, this is Ava with Think Crucial.
This is the manual of your Holmes model number: Holmes HAP9422 Product Manual Hope this was helpful.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
Ava B.
Think Crucial Customer Care
Apr 09, 2015 | Holmes Products Air Purifiers
On my 60gb ps3 I was having problems with it freezing after 10-15 mins of gameplay on the loading screens, I have had it since around 2006 so my warrinty was up. I took it apart and cleaned all the dust...
Hi Max,
If your PS3 is freezing up then you need to stop the heat build up internally and to do this you will need to get it repaired.
Now you can send it in and they will fix it for you that is the standard method however bear in mind that there will be a repair charge of $150 for the fix which is quite steep!
The other way that you can fix it is by using a good PS3 Repair guide.
Just a quick word of advice though, make sure you check out these reviews of the top guides so you can be sure what they offer.
Click Here To See PS3 Repair Guide Reviews
Hope this helps.
Mar 31, 2011 | Sony Playstation 3 (PS3) Console
I dropped my Ps3 on the ground & now it just has the YLOD. Is it completely broken or could it be fixed?
PS3 MoBo Reflow Guide
This will only fix certain motherboard issues. This fix will solve YLOD issues cased by the system getting so hot the CPU / GPU or direct chipsets get shifted. This fix uses a heat gun to heat up the CPU / GPU and direct chipsets and allows them to fall back in place.
I used a standard heat gun (dual, High, Low settings). Check the temp on it though. You want it around 700-750 degrees Fahrenheit.
Some Additional Tips Not In The Guide:
  • If you have worked on PCs this shouldn't be that hard. If you have worked on Notebooks, you shouldn't find the PS3 to be very difficult at all. Most notebook chassis are far more tedious then the PS3's.
  • DOWNLOAD THE GILKSY GUIDE!!!! Read the guide a couple of times. Note the manner in which the PS3 is sitting in each photo.
  • Have the guide open on your notebook or PC as you work. Otherwise print it out.
  • Make sure you have enough time to take it apart and put it back together. It will take about an hour maybe an hour and a half. You don't want to take it apart then try to put it back together the next morning.
  • Make sure you have a clean work area. With PLENTY OF LIGHT, I used my kitchen counter.
  • Have places to sit parts out of the way.
  • Have the right tools, you don't want to strip every screw.
  • Get a ground strap in addition to the tools outlined.
  • Have several containers to keep the screws in, one for each level of "disassembly" is what I used.
  • Careful getting the first rubber foot off, I trashed mine.
  • Keep track of where the coarse threaded vs. fine threaded screws come from. The coarse threaded screws generally screw directly into the plastic chassis.
  • Clean the pieces as you disassemble the PS3, a vacuum with a hose attachment and canned air work great. Stubborn dust bunnies may require a paper towel dampened with alcohol.
  • Keep the work area clean as you work. Be careful not to vacuum any screws. This will insure no dust (or pet hair) get into the new thermal CPU compound which could severely effect it's performance.
  • When you get inside the system get a sniff of your power supply, if it smells burnt, this fix MAY not work.
  • A few minor steps are missing from the guide, but they are fairly easy to figure out.
  • Careful with the ribbon cables, each one has a clip to hold them on. Some release the opposite way of others.
  • Righty tighty, lefty loosey!
  • When assembling the PS3 make sure you have all the cables where they should be as you put it together. You don't want to have to take it back apart a bit to get a cable where it's supposed to be. Be sure ports meet the port-holes as they are supposed to. Over all everything should have a tight fit.
  • When you put the screws back in you just need to secure everything, you aren't entering a strongman contest. Over torquing these screws may result in a funny looking PS3.
after following that there are 6 more parts to it ... (linked in the Description of that Video)
Mar 02, 2011 | Video Game Consoles & Games
My ps3 reads system is to hot and shuts down within five minutes. I don't think the fan is working at all. No warranty how can I fix this myself? I know how to take ps3 apart and I've cleaned the dust out...
Try upgrading the firmware as well.. Or doing a factory reset..
The error code could simply be stuck, and an upgrade or system restore may fix the issue if you have already cleaned the fans.
Aug 17, 2010 | Sony Playstation 3 (PS3) Console
Trying to update my ps3 and it keeps saying error 80710723 wot can i do
My 80gb ps3 did the same exact thing. I kept trying to get to install, but it just would not. called SCEA and they told me i'd have to send it in and pay about $200.00 for a refurb. So, i completly took it apart. Cleaned every thing, put new thermal compound on it. AND, presto install completed now i can use my ps3. Did not reflow just cleaned and new compund. And learned I should just update using USB flash drive. Works like a charm. Good luck. Hope this helps.
Apr 01, 2010 | Sony Playstation 3 (PS3) Console
When I turn system on goes right to menu screen. Wont play games or movies. Reset default settings 3times, and nothing.
how old is the PS3 and how much smoke and dust has it been exposed to? there are several excellent videos on youtube showing how to clean the lens. if your machine isnt under warranty anymore then you cant void it by taking it apart. please understand im not telling you to dismantle your machine but I took mine apart, cleaned the lens and had it back together in 30 min. it has worked fine to this day.
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
Will not read disc
open your PS3 up and use a dust cleaner to blow the dust off!it could be overheating. and if that works next time you play pull it out of a confined place and when youre done wrap it in a towel and put if where it should be to prevent dust getting in
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
Loud fan
i believe you need to clean out your ps3 of dust, usually dust clogs up the cooling system and decreases its efficency causing alot of strain on the fan due to it having to compensate so, try putting the "nozzle/tube" of a hoover (vacuum cleaner) over the air vents to **** the dust out,
You can take it apart to clean with a brush but this will most likely void all warrenty and your ps3 and you might not know how to put it back together so unless you know how to take apart a ps3 DON'T, otherwise do so at your own risk
Aug 11, 2009 | Sony Playstation 3 (PS3) Console
Model KF-42WE610
Major job to disassemble this unit to clean it. I recommend a qualified Sony tech to do this. With great care and a very sharp ended blade the from protective shield can be cut off, but the Sony two sided tape is no longer available. So it should only be done by complete disassembly.
Feb 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Ps3 wont read my disc or load my games
pick up a hammer , lean over ur ps3 , pick it up in 1 hand and throw it up and smash it with the hammer. vowla, it works!!!
Oct 23, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
