Question about Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Toner cart error K
  • 7 Answers
SOURCE: SERVICE REQ. C0082
C0082= CPU error ( TLB miss exception {Load/Fetch}), requires service personell to fix.
Posted on Jun 18, 2008
SOURCE: Epson Aculaser C1100 will not print properly after changing black toner
I have had this problem with a couple of our C1100's the solution is simple but a bit fiddly.
open the lid and remove the photoconductor unit. what you need to do is clean the glass panel through which the laser shines (it is there honest). It id directly behind the toners but down near where the paper sits. Look at the photoconductor and see where the blue roller sits in the printer. This roller has the laser shone on it and then picks up the toner relaying it onto the belt in the photoconductor.
What i did was get a wad of strong tissue and use a screndriver to wedge it down the rear of the toners (in between the toners and the black plastic bar as you look into the printer with the photo conductor removed) and then slide it back and forth. I actually learned this one form some Minolta QMS printers we have, but the glass plate was in plain view on those.
Basically what we had happen was that some toner had dropped onto the glas and was blocking the laser from hitting the roller and this lead to blank (or faded) strip along the length of a page.
I suppose a smallish paintbrush would do the same thing.
Posted on Dec 23, 2008
  • 5 Answers
SOURCE: what colour is K on low ink
the color K in the cartridge is the black cartridge or mono
Posted on May 15, 2009
Ranglo
  • 1194 Answers
SOURCE: Epson Aculaser C1100 error code C0084
Hi
The issue cause due to temporary "data error" that is easy to resolve. :-
  • A corrupted or interrupted print job, or:
  • A data or interface cable that is not connected correctly.
So, follow these steps:-
  1. Disconnect the printer from the data source
  2. Does the printer pass its ROM, RAM and Self Test checks?
  3. Test the printer standalone by printing a Status Sheet
  4. Cancel all pending print jobs on the network or computer
  5. Reseat and reconnect the data cable at both ends
  6. Test the printer
For more description view the following link:-
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1374
Posted on Feb 15, 2010
Testimonial: "Many thanks info spot-on "
SOURCE: How do you remove the other cartridges from the
On the left hand side is a lever. Pull down door 'A' and on the Left hand side you will see the arrow indicating the toner guide placement.
Directly to the left of this is a slot. Insert a biro (screwdriver or whatever fits) into it and push the lever UP to allow free rotation of the drum assembly.
Posted on Mar 30, 2010
My Epson Aculaser C1100 shows 'change toner K'
I've just replaced the the Yellow and Magenta colour toner based on your fantastic advice...
gbdmequick
Jul 17, 2012 | Epson Aculaser C1100 Printer
Toner Cart error K What is it?
According To Epson The cartridge you have inserted is the icorrect one. It is similar but not for this printer.
Please rate my help++++Thanks for using FIXYA
Jun 10, 2010 | Epson Aculaser C1100 Printer
Where abouts is toner k
K toner is refering to black toner. Here is a link to Epson for your Aculaser C1100 Reference Guide. Look under Setup & Maintenence for >Replacing Consumable Products..... click on 'Toner Cartridge' for the proceedure.
http://support2.epson.net/manuals/english/page/aculaserc1100/ref_g/index.htm
Nov 27, 2009 | Epson Aculaser C1100 Printer
What colour is K on low ink
Toner K low refers to the black toner.
May 15, 2009 | Epson Aculaser C1100 Printer
How to install toner chip on epson c1100
The toner chip is situated on the end of the toner cartidge - it's a circle, about 1.5cm in diameter.
They may have given you a new housing, in case you damage the one currently on your toner, when you try to remove it.
Nov 15, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Oct 28, 2008 | Epson Aculaser C1100 Printer
Unable to clear error
Have you replaced the K Toner? If so then rtry replacing it. It may be empty and the printer is monitoring a lack of toner in the delivery.
If you have replaced it and still shows it empty, the cart could be faulty. This is fairly common
May 09, 2008 | Epson Aculaser C1100 Printer
Replace toner k
Replace black toner with new
Nov 27, 2007 | Epson Aculaser C1100 Printer
Epson c1100
you may have replaced the cart with a faulty one. It does happen occasionally. Get another cart and swap that one also. If the error clears, return the original full cart for a refund as faulty. If the error does not clear you may have a problem with the receiver on the C dev and it will need an Engineer.
Sep 04, 2007 | Epson Aculaser C1100 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Epson Aculaser C1100 Printer Logo
152 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
