Question about Sharp Televison & Video
Iv'e been trying to turn my tv on for an hour but the led light just keeps flashing why won't it turn on?
    President:
  • 1,654 Answers
The flashing light is a service code for a technician to let him know there is trouble with the set. Most common issue on these is the power supply or one or more of the circuit boards. You can try a reset by unplugging the set and let it sit for an hour or so, preferably overnight then plug it back in this sometimes clears codes and then it can resume.
Posted on Apr 08, 2011
2 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: My sharp Aquos LCD TV
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem......
Posted on Jan 27, 2011
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
When i try and turn the tv on only the timer light flashes and keeps flashing for a few seconds then stops but the tv never comes on. What do i need to do? Is it worth fixing?
Yes,The LED light indicator"LAMP"flashes?The projection bulb on this tv have never been change about the last 1 1/2 or 2 years,and the tv been on at lest 4 or 5 hours in used a day?The projection bulb require changing,the bulb life span is over.
Jun 02, 2010 | Samsung HCM4215W 42" Rear Projection...
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Red light keeps flashing tv will not turn on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Mar 30, 2009 | Toshiba 57H82 57" Rear Projection...
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Feb 01, 2009 | Home Security
Televison & Video Logo
442 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
