Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Officejet Pro 8500A Keeps saying paper jam..... no paper stuck anywhere I can see. Turned it off and on and goes on for hours and hours saying it is "checking printer, may take several minutes". Everytime you turn if off, it says this again but nothing happens, left it all night and it is still saying the same message in the morning? Could you advise please? thanks Jackie
Try going to:SetupReportsPrinter Status Report.
If its going to print, it will here, and then hopefully it will make the printer work correctly again.
I tried this today and it has worked.
Posted on Oct 12, 2011
Reach in and wipe the paper feed rollers with a damp rag, It will fix the problem.
Posted on Apr 18, 2011
I get broken gear in my hp officejet pro 8500a
Someone pulled hard on jammed paper to remove it from the printer. This has broken the small plastic paper advancing gear on the left-hand side of the printer (have seen this mistake a number of times). The printer is broken and cannot be fixed, and it is time to purchase a new one. What you and everyone needs to learn from this is to NEVER pull hard to remove paper out of your printer. Be careful, and open the access doors to get to it.
We would suggest that you upgrade to an HP 8600 series printer and if you print more than 500 pages per month you purchase an AdaptiveInk continuous ink supply system (CISS). Adaptive Ink Continuous Ink Supply System Home Page Adaptive Ink HP Pigment ERC
Mar 12, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Hp 8500 printer keeps jamming
Are you getting the paper jam message on the display?
This is the standard real paper jam video. http://www.youtube.com/watch?v=pFKiGpkyZ1g
The real issue may be the white cog gear under the black shroud located in the lower left hand corner of the unit. http://www.flickr.com/photos/63431470@N05/ The gear can break or crack and cause a false alarm. There is a super glue fix out there but it isn't for everyone. Caution do not glue the gear to the shaft. The internet thread is here: http://www.fixyourownprinter.com/forums/inkjet/68498
I still have mine and it is not repaired. They just don't make them like they used to. Good Luck and I hope this helps you!
Apr 08, 2013 | HP Officejet Pro 8500A Plus Wireless...
It says jam but we do not see any paper anywhere
One of the paper sensors may be stuck or damaged
Feb 14, 2011 | HP Officejet Pro 850 InkJet Printer
It says paper jam but we do not see any paper anywhere
did you switch the machine on and off
one of the paper sensors may be stuck pr damaged
My printer is saying "Carriage Jam" and that I should remove Jam and press okay. I can not see a jam anywhere and have tried everything. Do you have any suggestions?
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things.
Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside.
Also the paper being used should be as per the manufacturer's recommendations.
Turn off the printer when removing bits of paper.
If there is a broken gear, do not repair it yourself. Call an expert technician to mend it. get more help for HP Carriage Jam .
Sep 20, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Nov 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Jam
maybe there is more than 1 piece of paper jamed
Jun 29, 2009 | HP LaserJet 4 plus Printer
Cleared paper jam &printer will not reset
I had to turn off the printer & disconnect the power cord. I also had some material that was backed up on hold from the night before that was preventing the current material from being printed & I had to go in & cancel the documents to be printed before the printer would function.
Jan 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Printer keeps saying paper jam but paper come through but it wont
c220ca5.jpgthere is still a piece of paper on a sensor or a sensor is bad
look for a sensor like this it should have the flag in the UP position as seen,
Nov 17, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
366 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
