Question about Belkin F5U027 7Port USB Hub
Belkin USB 7-Port Hub, F5U027 on MacBook Pro, OS X 10.6.6 - lights not working; whole thing not working. Took off the computer and tried its own and alternative transformer and red (on) light flickers on then off (dimly). Presume best option is to replace?
  • clogs746 Apr 08, 2011
    yes. Rapid and clear. The only problem is it confirms my fear that the device is bust! You might have a lower cost option for suspected dead kit?! Anyway it's cheaper than taking it to a mender...
    Master:
  • 346 Answers
Hi - You're presumption about the fix is correct. There is very little in terms of circuitry inside such a hub and even if one had circuit board level experience there would be no good reason to bother fixing it.
When you purchase another hub, remember in the case of such devices, a hub is a hub is a hub -- No reason to pay any name brand premium.
Regards and Thank you for using Fix Ya
Mikeywaf
Posted on Apr 08, 2011
How to download free driver for belkin F5U237
A driver is not provided by Belkin for this device. It should work with generic usb drivers found in windows or mac.
Feb 24, 2014 | Belkin (F5U237) 7-Port USB Hub
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
My belkin Hi-speed usd 2.0 7-port hub wont work and i cant find the CD that it said it came with. what do i do?
go to this site and download the driver for it. The CD basically contains the driver software. You can easily get it online.
http://download.cnet.com/1770-2014_4-0.html?query=Belkin+Hi-Speed+USB+2.0+7-Port+Mobile+Hub+-+hub+-+7+ports+-+desktop&searchtype=downloads
just select the correct operating system and install it on your computer. Let me know if you need any more help.
May 12, 2011 | Belkin (F5U237) 7-Port USB Hub
My OS is Windows Vista Home Premium edition. Will Belkinns 2.0 x 7 port hub F5U237v1 will work with it?
Yes it will definitely work it no matter what operating system your computer is using it will be working fine.
Nov 25, 2010 | Belkin (F5U237) 7-Port USB Hub
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
Hello, I have a Belkin 2.0 USB 7-Port Hub, and having trouble with it. When i plug it into my computer, nothing happens, there is no power light and ultimately it seems as though the device is dead. ...
You first need a CAT 5 cable to go to where your internet connection is, such as a modem or another router to your hub. Then you plug another CAT 5 from the hub to your PC. You need to feed internet to the hub then your pc will recieve a connection from the hub. And of course the hub does need power. Hope that's what you were asking.
Mar 09, 2010 | Belkin (F5U237) 7-Port USB Hub
I can't seem to get the Belkin 7-port hub to work with windows 7. Whenever I plug a flashdrive into it, windows 7 doesn't give recognize the flashdrive.
windows 7 is a 64 bit OS, and still fairly new. A lot of drivers for hardware are not supporting 64 bit Operating Systems yet, maybe in the near future but right now a lot are not.
Temporarily or permanently switch to Ubuntu. I think this hub is compatible, and you can still read your Windows files in this Linux distribution.
Dec 30, 2009 | Belkin (F5U237) 7-Port USB Hub
My computer does not recognise my Belkin 7 port hub.
sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
Oct 04, 2009 | Belkin (F5U237) 7-Port USB Hub
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
Belkin F5U027 7Port USB Hub Logo
433 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
