I have lost my manual for my freeview+ and need to set my remote to operate the LG tv and the freeview box any advice
    Sergeant:
    Champion:
  • 286 Answers
You should be able to get a manual from the internet. Try typeing in the make and model of TV into google search engine. You should be able to get it then.
Hope this helps
Posted on Apr 08, 2011
One for all remote to work on technika freeview box and polaroid tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily........
http://electro-medical.blogspot.com/
May 28, 2016 | One For All URC-3445 Remote Control
Ive lost the codes for my remote can someone help me please
Go here to download the .pdf file. It will guide you in finding the right code for your product. https://www.u-manual.com/download-manual-now-for-free-10/135629/remote-commander-remote-control-one-for-all-urc-3920-ofa-2.html#.Vb5uWG5VhBd
Aug 02, 2015 | Toshiba Televison & Video
Can any1 help with my ikasu tv remote code
http://www.rockabilly.net/files/manuals/URC-7740.pdf
Download the manual and if your model is not listed follow the section called search method and the set will do it for you.
Let me know if this helps.
May 02, 2014 | Supersonic Televison & Video
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Installation code tv set top box
try 1 2 3 4 universal settings works with mine
Mar 02, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Omega urc-08 device codes
Original link no longer working. Found this: http://files.remotecentral.com/download/220/urc08-manual.zip.html
Comment if it's wrong one.
Nov 22, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
