My computer is being hanging - Computers & Internet
  • 639 Answers
Goto Strart and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'Sys config utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
goto 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications .
right click on each applicaion and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, trojan, or spyware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
If you feel that my answers has helped you in any way then please give a vote.
Thanks.
Posted on Apr 08, 2011
My laptop hangs when i open a progamme and see movie, my laptop is Dell vostro 1088, i installed new version of bios, but still hangs... i also format several times..how will solve this problem
You mentioned opening a program and watching a movie and it hangs, remove one stick of ram and see if there is a difference, if no! remove second stick and put back the first and test again, if this solves the problem the memory needs to be replaced.
Apr 03, 2012 | Dell Vostro 1088
Problem Event Name: AppHangB1
Check that your computer has the correct operating system for the game, and that the hardware is correct against the spec reqd. on the side of the box.
Mar 17, 2012 | 2K Games Sid Meier's Civilization V for...
My iaptop is hang wt to do
HI there restore the Operating system and thry again. If not done then you need to install the operating system again. Thanks.
Nov 29, 2010 | Dell Vostro 1014 Laptop Computer (Intel...
My computer is hanging
there are many reasons why computers hang, i will site some
examples and possible solutions:
it hangs probbly because you open a program or application that
is out of the capability of your pc, refer to your computer specification
and compare it to the specification require of the program or application you might want to install or run in your computer.
Another thing, computer might hang because it has full of junk files, something like temporary files saved from internet, there might also some registry values in your pc that is not needed and causes some
error or trouble that leads to hanging. All of this junk files and registry
should be cleaned or deleted. Try to download and install "CCleaner"
from Filehippo.com.
Hope all of this will help to everyone...Thanks
Aug 20, 2010 | Computers & Internet
AppHang81 Error-help!
what version of windows are you using? state the version and servicepack. in the intrim, start your computer in safe mode and run some programs. shut down the computer and restart in normal mode.
Jan 02, 2010 | Compaq Presario CQ60-220US PC Laptop
My laptop hang so many times in a day pls give me solution
get an active anti virus or reinstall everything to facotry mode
rate this
Oct 24, 2009 | HP Compaq Presario V6000T Notebook
Computer hangs on when in BIOS. also hangs when plaaying simple games like bookworm
hello...try remove all data cable connection/HDD IDE/SATA connection,CD/DVD IDE/SATA connection and then try to..if their is same happen try remove the memory then clean using a paper eraser all pin connestors..thanks and good luc to you..have a nice day
May 16, 2009 | Asrock M266A Motherboard
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
