Question about Toys
Have a chien ti ct650 elec. quad kids rideon toy dont have a battery 4 it cant find 1 looks like a plug with 4 leeds 1 hot 1 ground 2 other thats what i need
3 Suggested Answers
  • 3 Answers
SOURCE: looking for a replacement battery for a
More than likely go to wallmart by their bike rack and look i used to work there. they are usually over by the powerwheel toys.
Posted on May 14, 2009
  • 139 Answers
SOURCE: i have a new 50 cc mini quad for my kids and its
Try changing the spark plug making sure the gap on the new plug is at recommended specs.If the plug is black when you pull it out mix gas with a little less oil but not much as if it is to lean it can burn up motor make sure gas mixtured isn't to rich if you have to mix the gas and oil together yourself.
Posted on Sep 02, 2009
Testimonial: "thanks alot ill try that first"
Need manual for marble mania extreme 2.0 cant put it together without the instruction manual?
See the link for the manual and videos. That looks like fun!
Techno Gears Marble Mania Extreme 3.0 Instruction Manual
https://www.manualslib.com > ... > Toy > Marble Mania Extreme 3.0
Translate this page
Page 2: Getting Started. GETTING STARTED BATTERY INFORMATION FOR PARENTS AND KIDS inicio INFORMACI?N DE LAS BATER?AS PARA PADRES Y NI?OS ON/OFF SwITCh INTERRuPTOR DE ENCENDIDO/APAGADO Motorized gear uses 1 "AA" (UM3/LR6) size battery, (not included). ON DEMAND BuTTON ..
techno gears marble mania extreme 2 0 instruction manual Google Search
Jan 15, 2018 | The Toys
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
How do I fix where do I start I can rewire this place but when it comes to fixing problems sometimes I can fix and sometimes I can't .
I'd recommend replacing wire,but if that's to much work you can add a ground wire,first start by driving a ground rod somewhere close to your elec.service panel into the ground,then from there run wire to service panel ground,from panel continue with wire to outlet,switch,etc.at same time replacing with new ones
Jan 15, 2015 | Electrical Supplies
Need to wire a t30 242-5N with a 4 prong dryer cord help
on 4 prong,2 are hot 1 is common,1 is ground,,on 3 prong 2 are hot,1 is common ,you dont need ground,build your own plug
Wire Dryer Outlet
Sep 24, 2014 | Dryers
Quad copter won't lift off ground
Maybe battery is not accepting charge. I would try using a new battery.
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Cant find the place on the quad to plug the charger in.
try taking the battery unit out,the battery should have a plug that fits to the quad disconnect the battery from the quad. the square end of the battery lead should fit in the end of the charger.its not the quad you need to charge its the battery you need to charge,hope that helps
Apr 23, 2011 | Toys
Quad wont start unless jump starting from a car
ok buddy to start it you need 12 volts and you need the amps there because in a car battery theres 80 amps which will easily turn it over but dont keep attempting this as the wires will melt due to the power passing through them a lot and the carb problem is due to mixture on the carb is a mixture screw turn this all the way in and unscrew 1 1/2 turns out and try this also run a mix off 40:1 bbd2d5f.jpg
Sep 21, 2009 | 2007 Gas Gas Pampera 125
I have a new 50 cc mini quad for my kids and its bogging so bad it wont move my 4 year old? {2 stroke}
Sep 02, 2009 | RTO Mini Quads
Small unnamed quad, prsumed 49cc, wont fire only clicks.
take of the pull starter and look at the cog and pull the rope and if the cog pops up then its fine
Jun 28, 2009 | RTO Mini Quads
Toys Logo
300 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
