Question about Trendnet TEW-430APB Wireless Access Point - 54Mbps, 802.11g
I have instaled the TRENDnet tew-430apb, but, if i connect my laptop to the AP, i get connected but no internet access
Hi i have a problem with my router. Its only allowing one user to connect to it. It never behaved liked that when i bought it, so all of a sudden its behaving like that now and its really frustrating because i have more than one user in my household. Could some one help me solve this problem. I have a TEW-430APB C1 trendnet router.
http://www.squidoo.com/******-actives2
http://www.squidoo.com/waterproof-sealant
http://www.squidoo.com/apple-care-protection-plan
http://www.squidoo.com/smart-phones5
http://www.squidoo.com/dell-laptop-deal
Posted on Sep 14, 2012
3 Suggested Answers
  • 55 Answers
SOURCE: Trendnet 430APB 54Mbps 802.11 AP
if you press the reset button at the back holding it in for about 10 seconds, that should set it back to it's default. Then in your address bar log back into it. The default username is usually admin and sometimes the password is admin too. If not it's either password or there is no password so you can just press enter on your keyboard. This way you can set it up the way you want to. Just be aware that if you use WEP 128 bit, you have to have 26 characters as a password. If you use WPA PSK then you only need 8 characters. You should be able to access this from the word wireless in your options list. I would run the setup again first and then do all the configuration next. Lets hope this helps you out.
Posted on Jan 26, 2008
etaf
  • 779 Answers
SOURCE: how to reset the security key of my trendnet
To change your router wireless security
  • Support site here http://www.trendnet.com/products/proddetail.asp?prod=150_TEW-430APB&cat=83
  • User guide here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10853
  • Quick setup here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10856
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - Enter IP address http://192.168.1.100 to the address location. When there is a screen needs to enter the User name and Password, both of the default Username and Password is “admin”
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 12 of the User Manual
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --
Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Posted on Apr 13, 2010
We havea TRENDnet Wireless AP TEW-430APB - keeps dropping wireless
It can drop signal if there are other devices working in 2.4GHz band interfering with it. Try to switch over to 5GHz band.
Aug 29, 2017 | Trendnet TEW-430APB Wireless Access Point...
I have dsl modem routeur dhcp enabled with ap wifi ssid = x everything ok ip 192.168.1.1 i have tew 637ap n upgrader wire connected on dsl modem router with static ip 192.168.1.20 ssid = y everythings...
You may be trying to connect through a G or B device to your N router. Verify that there are no serious obstructions or that the pc is not underneath something or enclosed. Metal near the pc can cause the signal to lose strength. Not having a wireless N card or adapter can also cause this.
Also if you are trying to connect through ethernet cable verify that windows is being assigned an automatic ip address, if it is static in windows change it to automatic.
Apr 29, 2011 | Trendnet TEW-638APB 300Mbps Wireless N...
Ip address
You can get your external IP address by going here:
http://www.whatismyip.com/
You can get your internal IP Address in Windows by:
1.) Click Start
2.) Click Run
3.) Type in CMD, hit ENTER
4.) Type in IPCONFIG at the command prompt, it will display all of your IP Address's.
Mar 02, 2011 | Trendnet TEW-430APB Wireless Access Point...
Says I have an excellant connection - but will not connect to the internet
same problem. the network shows up in the connection list, has max wifi signal, password was not rejected, and still the cursor/icon just spins indefinitely and never connects. I have Dell laptop with windows vista using the newest Verizon Fios router.
Dec 23, 2010 | Trendware WIRELESS AP TRENDNET|TEW-637AP R...
How properly to connect TRENDnet TEW-432BRP to laptop
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 26, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How to reset the security key of my trendnet tew-430apb 54mbps wireless access point?
Feb 11, 2010 | Trendware TEW-430APB 802.11g/b (TEW430APB)...
How to change password for Trendnet TEW 432BRD wireless router
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
Have a WRK-54G Linksys wireless router. Have a
I had a TEW-421 card for a time, and it can not do WPA encryption, only WEP. It's not a driver shortcoming, it's the hardware in the TEW-421 card.
Sorry to tell you it's a dead-end, but at least now you know.
Oct 18, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Cant connect to the AP menu TEW-430APB
clear your browser cache, close, relaunch your browser and try again
You probably cant access it because you are not authorized. If its locked on your rooftop then your ISP should configure your access and that you're not authorized.
Jan 18, 2009 | Trendware 54Mbps 802.11g Wireless AP
Jan 22, 2008 | Trendware 54Mbps 802.11g Wireless AP
Trendnet TEW-430APB Wireless Access Point - 54Mbps, 802.11g Logo
516 people viewed this question
Top Trendnet Computers & Internet Experts
David Payne
David Payne
Lynne
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
