Question about Vocopro DKP-10G Digital Key Control CD/CD+G/VCD Karaoke Player
I don't know how to change keys. No manual. What do the osd and pbc buttons do on the remote, and the bscan and fscan buttons do on the machine?
  • Vocopro Master
  • 467 Answers
OSD means on-screen display (clock, counter, etc. if applicable). Press OSD button and observe the screen.
PBC is playback control (applies to Video CDs to allow the user to interact with them using menus) - not a very reliable function for this disc format.
B-Scan & F-Scan generally means back and forward scan (search) respectively. They're a bit like fast forward or rewind functions in a VCR - press those buttons while a music CD is loaded and see what they do. (probably skip forward or backward over a track and you can observe the counter display while doing so)
It's very simple really once you have done it a few times. The bonus here is that it didn't cost you anything to ask, and won't involve any repairs by a workshop, as long as the player works fine overall.
Posted on Apr 08, 2011
Can not change channels with up and down key
on the tv or remote please... if on tv child lock could be on if remote and tv could be the pbc board for the inferred . also using you phone camera press them buttons on the remote you should see a light come on the remote through your camera, if not the remote may be damaged so check other buttons.
Oct 02, 2013 | Vizio GV42L 42 in. LCD Television
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
I used to get OSD on the TV with my receiver, but it has gone and I don't know what setting to do to get it back. It is a Pioneer VSX-917V-s/-K. Thanks
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
Dec 30, 2009 | Pioneer VSX-917V-K Receiver
I need unlock codes and instructions for Palsonic DVD2040
try this
Insert any disc into unit, press the PBC button on your remote, followed by the play button, the PBC function should open the higher level menus thus allowing you to change RCE coding
May 24, 2009 | Televison & Video
How to region free code for JBL DVD PLAYER CINEMA SOUND 3
The model number would be helpful as well. Below are a few universal process's for JBL dvd players. Not 100% guaranteed..
Give them a try, if they don't work then post the model number for further info.
PROCESS 1
1. Turn on player without disc and wait for "no disc"
2. Press OSD on remote control
3. Press 314159
4. Press 0 for region 0 (or 2 for region 2, etc.)
5. Turn off player with 'off'
6. Ready.
PROCESS 2
1) Open DVD tray
2) Press and hold "6" button on remote control.
3) Press "Menu/PBC" button. The current region code will be displayed on screen.
4) Keep pressing the "Menu/PBC" button until the preferred region code is selected (0,1,2,3,4,5,6).
5) Press and hold the "Angle" button for more than 2 seconds to save the region code. "Writing Region ID" will appear on screen.
PROCESS 3
Volume off
Slide Open
Press volume+ for 3 sec on remote
Then press Language on remote fast
Then choose 0 for region free
Press ok
Good luck , let me know if one of them work. Thank you for trying Fixya!
Mar 21, 2009 | Televison & Video
Remote control touch screen is not working
Flip ipen the front face of the remote control so that you have access to the buttons underneath. Press and hold the "light" button on the outside right of the remote while pressing the "enter" button to the right of the number "1" button.
THIS WON'T WORK IF YOU HIT THE "enter" BUTTON BETWEEN THE ARROW KEYS.
The screen should now flash PRESS and VCR 2 - press the onscreen key marked VCR 3.
The screen should now flash PRESS aqnd OSD - press the onscreen key marked OSD.
Test all of the onscreen keys. If you find them still unaligned, repeat the process.
Feb 24, 2009 | Nakamichi SoundSpace 12 System
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
Vocopro DKP-10G Digital Key Control CD/CD+G/VCD Karaoke Player Logo
160 people viewed this question
Top Vocopro Televison & Video Experts
Electro Med Services...
Are you a Vocopro Televison and Video Expert? Answer questions, earn points and help others
