Question about Kitchen Ranges
How do you convert a Sunvision V180 xxl from 3phase to single phase? What size supply do I need?
2 Suggested Answers
SOURCE: i am looking for a
call 0808 108 7778 for all alisun sunbeds parts and trim, i have a 180xxl in my tanning salon
Posted on Feb 15, 2011
Juki SC-800 3phase. How do I make it run on single phase? Tried VFD. Gives alarm 0001 and beeps.
If a VFD won't work you are best to obtain a single phase motor of Chinese origin. They are inexpensive and available widely on eBay. Just make sure to get one within the rating of your fixed supply wiring. You can also get mounting plates of different sizes.
Dec 27, 2016 | Juki Sewing Machines
I have Hobart D300 mixer which operates at 220V, 3phase supply and whereas the facility has 208V, single phase supply. Is there any recommended phase converters available for this product. Thanks
Hi Bill
I may be wrong here......
But I've been around Electricity for a long time.
Have Never seen a device that does phase conversion.
A Building site or home will either have Three Phase or Single Phase Power Available
BUT...A portable (Hired) generator could be "three phase" and you could use any one of those phases individually or all three phases.
I have 3 Phase supply to my house!
But I use 230 volt Single Phase for appliances.
My Bore Pump uses a 3 Phase Motor,
(so with a voltmeter it would read about 440 vAC to the pump motor).
Some Further Info:
A GENERATOR is basically a motor used the opposite way. Rotate a motor and it Generates.
The Phases refer to the THREE Windings in the supplying generator in your suburb.
A Large Magnet passes each winding in sequence giving you the three ripples in the supply.
Our houses can choose to have 1 Phase or Three Phases from the street when you set up your electric supply.
So... to confirm, look at the wires on the supply poles to the premises. Usually three in our area (Oz)
Most people are not aware that a car Alternator is actually three phase. The Rotor is the magnet that rotates.
The only difference with an Alternator is that each "Phase" is connected to 2 Diodes (6 total) to convert the three phase to DC to charge the vehicle.
The Regulator controls the voltage to the Rotor, thereby controlling the output.
So.... An Alternator could in theory supply 3 Phase in a mobile generator. Custom Made. Constant speed would determine the frequency of 50Hz or 60Hz.
Not sure what country you are in
Hope this Helps or gives you food for thought!
Three phase electric power
Jul 08, 2015 | Hobart Food Mixers
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
I am looking for a users manual for a alison sunvision v180 xxl sunbed to see how it is wired to the electrics
Jan 05, 2011 | Kitchen Ranges
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
Need to convert 3 phase Hobart dishwasher to single phase
It will not be inexpensive to convert your dishmachine over to three phase. With everything that you will need to replace, depending on the model if converyor or not it may run close to what it costs to have 3phase run to the building that you plan to move into.
Jun 08, 2009 | Dishwashers
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
Wrong voltage rating
Hello. If the unit is rated 460v, 3phase, the only way you can get it to meet your supply of 208v, 3phase, is:
a) have a transformer installed to make 460 from your supply by an electrician, or call your power company and see if 460 could be supplied to your building, but it would only be for that machine.
or
b) replace the heating elements for the 208v supply, have the pump motor checked to see if it will work on 208v, and a control transformer for the control circuit, as well as all the wiring related to the pump and heaters, as on 208v, they will draw more current than on 460.
so, can it be done? yes. Is the expense worth it? only you can answer that, However I would suggest that you resell that machine, and get the correct one from the start.
Hope that helps, and thank you.
Feb 16, 2009 | Jackson 25 in. TempStar HH Free-standing...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
