I have EZ-VFR for FS 2004 Just switched to windows 7, 64bit This software will not load. is there an update or new software for windows 7?
  • Edward Hartman Apr 10, 2011
    Thank you John, I will try doing this and see if it works and let you know.
    Ed
    Guru:
  • 811 Answers
With that old of a system 2004 I would load a 32 bit Windows 7 on your computer. The 32 bit will load on your computer this is the standard software to load into most home PC's or laptops. It will not load because you do not have the right amount of resources to accept the 64 bit version. You can obtain one at any computer outlet store or online. Get the 32 bit only I hope this assisted you please vote for me and thanks for using FixYa! John
Posted on Apr 08, 2011
1994 HONDA VFR 750 BIKE WONT COME ON AFTER BLOWN TURN SIGNAL FUSE AND SPARK FROM FUSE BOX WHILE BIKE WAS ON PUTTING IT IN
Hi, Mary you may have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away from the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VF750C Owner Manual
Honda VFR 750 FR FS FT RC36 94 96
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 20, 2016 | Honda Motorcycles
Ez vinyl converter
Yes it's painful... Manufactures and vendors FIX the items that have THE MOST complaints, but often build in NEW problems with devices that worked before!
TRY going back to a older version(s) first... ESPECIALLY true if your device worked BEFORE the latest update... HERE is a GREAT Site for you and others:
Old and New Software Version Downloads OldApps com
IF you need a older version of X program... you should find it there!
Anthony
Dec 15, 2017 | Sony Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
2004 Honda VFR 800 normal engine temperature
Hi, Terryk24 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
What Is Normal Operating Temp New To Vfr
VFR800 Fi 2000 Operating Temperature
HONDA VFR800FI VTEC RC46 2002 2013 WORKSHOP SERVICE MANUAL Download... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda VFR800A 2005 Owner Manual
Jun 25, 2011 | 2004 Honda VFR 800
2004 Honda VFR 800 once warm starts to smell like burning rubber
Hi, Adrianhearst I would inspect the exhaust system and check the rear wheel for rubbing and pieces close to the pipes, for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
New to motorcycle maintenance Odd burning smell from front of bike started...
Weird smell coming out of Sprint
VFR800 INTERCEPTOR 2002 HONDA SERVICE REPAIR MANUAL Download Manuals... $15
Honda VFR800 Owner Manual
Nov 16, 2010 | 2004 Honda VFR 800
Can't load my burner
The CD Burner drive is compatible with your Windows XP the software version is where the problem is. You need to get an updated version of the burner program, something like Nero burning ROM or Roxie EZ CD creator.
Buddy
Corporate Computer
May 15, 2010 | Acer (99.B0112.102) CD-RW Burner
Looking for the Vupoint Filmscanner driver. Thanks for helping..
Hi Thierryghi,
thanks for explaining in detail.
Please download the driver for your device from the below link.
ftp://vps:vps@66.185.19.4/Drivers/FS-C1-VP.zip
But I am not sure whether it will be compatible from Windows 7.
Try installing the driver. If not installing on win 7, then right click on the setup.exe and select properties. There select compatibility to windows xp as something similar like below.
After installing the driver, you need to install software so that you can use that software to scan.
Please download the software from the below location and insatll this as well after installing the driver.
ftp://vps:vps@66.185.19.4/software/PhotoImpression_6.1.8.130(new).zip
After installing this s/w you will be getting some shortcut in desktop using which you can scan your film.
I hope this will be useful to you.
Thanks
Mar 10, 2010 | Office Equipment & Supplies
Problem with my Asus p5pe-vm motherbord.When i start it,the message CPU uCode loading error appears.What to do...HELPPPPPPP
If your over clocking your CPU settings reset to default. See if you still get the error. If you still get the error than update your bios. There are a couple of way to do this. You can use the software on your Asus CD or you can down load the latest BIOS-Utilities, Afudos BIOS update tool V2.36. Than download the bios file, P5PE-VM BIOS 1501.
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
Using built-in EZ Flash to flash BIOS Please be informed that not all motherboards support EZ Flash,
please use DOS flash utility to update BIOS if your motherboard does not support EZ Flash; http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=960&SLanguage=en-us
Happy holidays!
Mike
Dec 19, 2009 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
David Payne
David Payne
