Question about Edirol FA-101 (FA101) Audio Input
No sound comes out of the outputs or headphones. everything seems to be connected properly.
  • 27,725 Answers
If you are refering to the headphones on a computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Posted on Apr 08, 2011
LG 55LS4500 55 in. TV has sound through speakers, no audio except a hum from headphones and the optical digital to analog output fiber lights up but no sound output What board is bad?
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Feb 26, 2017 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
Why am I not getting sound anymore?
Amplifier issue. See if you are getting audio signal at audio outputs used for recording. If not, then it is NOT the audio amp and the proceeding circuits are responsible.
U might also want to check out your power supply voltages to make sure that the other components are being properly fed.
Feb 05, 2016 | Denon DRA-397
I have no sound from my games i think i have tried everything HELP
Ensure your audio cables are connected to the proper output connections. You can also troubleshoot by testing a headphone outlet jack.
Oct 30, 2014 | Video Game Consoles & Games
After opening my laptop and putting it back together, theres no sound from my speakers.
The speaker and headphone connections to the motherboard may not be connected properly.
Jan 24, 2013 | Sony VAIO VGN-NW120J/S Laptop
I want to watch some videos on my sharp lcd but using headphones without any sound coming from the speakers, but I don't find any headphone output. How can I do this??
First, since there is no proper headphone output on this television some people have been able to find an adapter to connect their headphones to. The other end of that adapter has a red and white RCA audio cable on it, and it would connect to your television's audio output. However I have heard from some people that they only get one volume level that cannot be adjusted when it works. Alternately you can connect your television to a sound bar or sound system that has an actual headphone jack and RCA audio inputs. If you still have a "boom box" sitting around with the RCA audio inputs you can connect the television to it as well. You need something to serve as a go between/center channel for this television that you can also connect your headphones to.
Jul 22, 2011 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
No sound on my Samsung Syncmaster 920lm Monitor
This seems to be easy.
1) Your monitor will need to be connected to the sound output using a separate cable, unless it uses HDMI cabling.
2) If that doesn't help, check the sound output using headphones or a different speaker system.
Check it out and post your response here.
Oct 09, 2008 | Computers & Internet
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
No sound output
are you hooking up the headphone jack to the unit and not the ibook? When I hook inspire to my mac, the output comes from the unit, not the computer through the unit's headphone jack or the speaker output. Also make sure the volume is up and no channels are muted.
Aug 19, 2007 | PreSonus Inspire 1394 Sound Card
Edirol FA-101 (FA101) Audio Input Logo
143 people viewed this question
Top Edirol Televison & Video Experts
Are you an Edirol Televison and Video Expert? Answer questions, earn points and help others
