Question about Motorola Computers & Internet
How do i program channels on the motorola cp476 uhf?
  • david pazsa Apr 14, 2011
    Thanx mate but it doesnt tell me how to program the channels. The uhf is locked on ch 20 but when i go to another channel it automatically goes back to ch 20
  • 492 Answers
Http://ap.cgiss.motorola.com/asset/pdf/MOTO_CP476_LORES.PDF
Posted on Apr 11, 2011
My Cp200 can't connect to my new Motorola Talkabout T5720 (7 Channels) 2-Way Radio, need HELP
The CP200 is a dealer programmable radio which was available in UHF or VHF. You would need the UHF model to match. Then the radio itself would need programmed to the same frequencies as the T5720. This requires Motorola proprietary software, cable and radio interface box (RIB). Your best option would be stopping by your nearest dealer to have it programmed.
Oct 21, 2015 | Motorola CP200 Two Way Radio
How do i sync Two-way radio AAH84RCS8AA1AN
These are dealer programmable using Motorola proprietary software and the appropriate cable. Most Motorola dealers could program one or more of the radios for you.
Mar 16, 2014 | Motorola MagOne BPR40 UHF 8-channel...
I pulled u uhf out of my vehicle and replaced it with a pro 520 xl uniden uhf but it won't work.
Check your electrical connections and your antenna set up first. Then if you still have a problem, check your mic/mic plug. Lastly, check your programming. If you have ignition sense programmed into the radio you will need to wire it accordingly, so it will sense the ignition of the vehicle.
Best regards.
Sep 13, 2013 | Motorola UHF 1-Watt, 1-channel Radio
How do you set the radio back to default settings. AXU4100
  • HI, I can help.
  • You will have to contact an authorized Motorola dealer such as http://www.buytwowayradios.com/products/motorola/motorola-ax-axu4100.aspx or any reputable two way radio store in your area. Those radios are still very programmable. I wish there was some way around this but there is not and Motorola gets very grumpy when unauthorized people end up with their interface because it is in fact quite the money making racket.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | Motorola AXU4100 (10 Channels) 2-Way Radio
How to reprogram two way radio, its a motorola gp 339 and its set to 5 channels from when i brought it, can i reset it or reprogram it to normal uhf channels?
In order to reprogram this Motorola GP339 you need to have a programming software, radio interface box and programming cable for this radio then you can read and change frequency in it. To reprogram to UHF channels this radio must be in UHF band. Good luck!
radcom907
May 14, 2010 | Motorola GP300 Compatible 2 Way Radio...
I can't retune the channels on my motorola xtn
Sorry, but the XTN446 has only the 8 channels pre-programmed by the manufacturer.
Channels 8
Codes 121
Frequencies 446.00625 MHz
446.01875 MHz
446.03125 MHz
446.04375 MHz
446.05625 MHz
446.06875 MHz
446.08125 MHz
446.09375 MHz
Here is a copy of the spec sheet: http://www.comm-spec.com/pdfs/radios/Motorola-XTN446-UHF-License-Free-100225.pdf
Best regards.
Mar 27, 2010 | Motorola XTN 2-Way Radio
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Can nice motorola GP340 talk to an FRS/GMRS w/ interference code?
If your GP340 is a UHF model, YES, you can have it programmed to match your TalkAbout radios. And yes, the GP340 has programmable privacy code capability.
If you do not know if your GP340 is VHF or UHF, you can tell by looking the model number, it will contain the following pattern: __H25RCC4AN3__. UHF models will have the letter R after the "25". VHF models will have the letter K.
When you have your GP340 programmed, the power setting will need to be turned down to the appropriate level to match the TalkAbout radios. Both for legal reasons, and also to protect your TalkAbout radios. You will not want the powerful GP340 to overpower the PA (power amp) in your TalkAbout radios.
May 10, 2009 | Motorola Talkabout T5500 (7 Channels)...
Compatability
Any programmable UHF 450-470MHz mobile radio could be programmed to the frequencies of the Spirit MU series radios.
Your radios are 2 watts, so you would probably want to stay with a 1-10 watt, or 10-25 watt mobile radio, to have the best success. The current compatible model for Motorola is the CM200 UHF radio. If you are looking at a used radio, just simply watch for it to be UHF 450-470 MHz.
Then when you are ready to have the mobile radio programmed, the dealer (or programmer) will need to know the settings of your MU radios. These are easily read out over the phone, or in person by an experienced programmer.
Dec 13, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Compatability
would a MU21CV be a VHF or UHF????
Aug 12, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Computers & Internet Logo
538 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
