Question about HP LaserJet 2820 Printer
Line down the center of page
I'm getting a large brown line about 1" wide all the way down the page. I just recently changed the drum, and it seemed to work fine for a couple of days after that.. Could it be a defective drum unit or does it sound more like the Fuser Unit?
  • deb4 Aug 10, 2008
    As it turns out, it was not the fuser unit, but a DEFECTIVE DRUM. I was given 2 good answers; although not from this forum. One was a recommendation to put the old drum back in and print a page. The line was not there, so I put the new one back in, and printed again, and the line was there. That pretty much put the problem on the drum. Second good answer, I suspect, although I didn't test it, was to start to print, but stop in the middle before it has time to fuse the text on the paper. If the paper is blank, it is the fuser, but if the line is already there, it's the drum.
  • HP Master
  • 6,487 Answers
This can be a problem with the fuser , base from the description of the problem that you're encountering now and also you said that the drum is almost new...
Posted on Aug 06, 2008
I have a MFC7440n - it developed a line vertically just to the left of the center, not a clear line, kind of smudged almost 1/2 in. wide. can't seem to clear even when changing toner, air spraying, etc.
Check the drum life and replace it if near end. Clean primary charge corona wire if the drum is still new.
Most likely the drum cannot be cleaned properly by the cleaning blade due to wearing or cannot be charged before developing due to dirty corona wire.
If this cannot help check the fuser's hot roller for tearing/scraching and replace if necessary.
Aug 02, 2010 | Brother Office Equipment & Supplies
Two inch wide black lines down center of paper
It probably the cleaning blade on the drum unit ( deformed rubber blade )
Mar 24, 2009 | Sharp Office Equipment & Supplies
Brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Feb 02, 2009 | Brother MFC-7820N Printer
I am getting a faint line all down the page
Most likely you have a defective black toner cartridge. Open the front shutter on the black toner and look at the drum. If you see the drum has toner on it corresponding to the line down the page, you found the problem. If you can't see anything on the drum try printing a page and then interrupting the printout while the page is still in the printer. If you see the line on the page before it goes through the fuser, (the last roller thing on the top of the printer) then it still is the toner cartridge. If it occurs only after the fuser then it, the fuser, is at fault.
Jun 29, 2008 | HP Color LaserJet 2600n Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
I have exactly the same problem with a Canon Pixma MP800, I have cleaned the rollers, changed the ink cartridges and reset the printer. It will print a few pages cleanly then dump black ink on the roller which leaves a heavy black line on the back of the page. It fades away after printing about 10 pages and then a few pages later appears again. The printer is two years old and it looks as if I must buy another. Should I buy another Canon?
Apr 03, 2008 | Office Equipment & Supplies
Line down center of page.
Hi Sherrey, I think I can help! If you open the ADF cover where you insert your pages to make a copy. You will see a scanner glass about 1/2 inch wide and runs across the width of the printer. You can take a soft towel and some glass cleaner and clean the glass. There will probably be some white build up that looks like white out on the glass just make sure you clean it very well. I hope this helps!!!!
Dec 04, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
HP LaserJet 2820 Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
